5th and 6th Sleeves
Old Feb 4, 2008 | 01:18 PM
SCCAITS's Avatar
SCCAEP
5th and 6th Sleeves
I've got to pull my intake to swap it and have a question on the 5th and 6th sleeves. It's an unported S4 NA motor with S5 rotors and soon the S5 intake.
Should I remove the sleeves entirely?
Or
Should I keep the sleeves and use Pineapple inserts?
I did some searching but most of it pertains to street cars, this motor does not see below 5500 RPM. If I keep the sleeves, the ports will be wired open. I've read a lot on the Pineapple inserts, no need to rehash that argument.
I tried calling Pineapple but couldn't get anyone on the phone, somehow I got into their VM system and it said 51 new messages. Then I got a busy signal when I tried to call back. Not sure what's up with them right now.
Old Feb 4, 2008 | 03:01 PM
Shainiac's Avatar
Id say remove them. While your at it, remove the spring rod in the LIM that turns them also. Those rods along with the pins in the sleves would obstruct flow worse than the sleeves themselves. If the motor is never going to see low RPMs, theyre just in the way.
Old Feb 4, 2008 | 04:09 PM
Silkworm's Avatar
Has been.. hangin' around
Unless they've changed the rules since I paid attention to IT rules, swapping to pineapple's sleeves would be an illegal modification.
Removing the stock sleeves would be legal, covered under 'removal of smog equipment'
I removed the spring rod and replaced them with aluminum blanks.
PaulC
Old Feb 4, 2008 | 04:39 PM
SCCAITS's Avatar
SCCAEP
PaulC
You are right but I don't race ITS anymore Check out my signature, I know my screen name is confusing but don't know how to change it.
Old Feb 4, 2008 | 05:14 PM
Latin270's Avatar
Go for the inserts. It does improve flow considerably.
Old Feb 4, 2008 | 05:58 PM
Silkworm's Avatar
jeez, what other mods did you do to turn that into a PTC car? Most of the ex PS-1 2nd gens are in PTD out here in cali.
Old Feb 4, 2008 | 06:58 PM
SCCAITS's Avatar
SCCAEP
A decently built ITS car does not make PTD, can't be done. I bet they are missing points somewhere, could be the .756 5th gear, 4 pot calipers, LSD, metallic bushings (how 'bout those aluminum DTSS elminators from Mazdaspeed?), rev limiter clipped ECU. Heck, I even re-designed my Speedsource design splitter and built one without the air dam to save points. All my "spare points" I am using for weight, as I do more power mods to the car I will add weight to stay in PTC. I also may still go with Miata gears in the box and have some other power mods in mind.
Base Class PTE
Tire Size 225 -1
Pulley 1
Air box 1
Fuel Pressure Regulator 2
Exhaust 5
LSD 3
5th Gear .756 3
Shocks 3
Springs 2
Sway bars 2
4 pot brake calipers 2
Metallic bushings 3
Front Strut Bar 1
Tire - Hoosier 10
Weight 2800 Curb - 215lbs = 2585 Comp 15
Clipped ECU 5
Spliter 2
Total 59
MAX 59 PTC
How are you going to get rid of 20 points? You are capped at 150lbs ballast. Even at ITS weight of 2680 your are + 8 on weight, so now we have 13 points to lose. Go with the RA1 tire and you have 8 points to lose. Tough to do, you need that clipped ECU. You could ditch the metallic bushings, lose the .756 gear but still have 2 more points to get rid of. PM me if you want to discuss, would be glad to talk about 2nd Gens running PT.
Back to my question, sleeves with inserts or no sleeves? I am still undecided.
Old Feb 5, 2008 | 02:39 PM
Latin270's Avatar
sleeves W/ Inserts Dammit!
Old Feb 5, 2008 | 04:16 PM
SCCAITS's Avatar
SCCAEP
Are you sure? Just kidding.
I just tried calling Pineapple again, rang and rang then fax machine picked up. I can't get anyone to answer, unable to leave a VM and we'll see on an email, it's been 24 hours is all. I'm afraid to order if they may not be around?
Old Feb 5, 2008 | 04:52 PM
SCCAITS's Avatar
SCCAEP
Alright, going with sleeve inserts. Got an email back from Pineapple.
Use the sleeves w/ our inserts. If allowed, when the motor is removed, consider removing the cross pin from the sleeve and fix it into position by drilling through the plate from the outside. I use a M6 x 1.00 allen set screw. I drill through the plate, sleeve, into the insert. Then install the set screw w/ loctite or similar. Then peen the screw. You can now remove the "pickle fork" from the intake air flow.
Old Feb 6, 2008 | 07:57 AM
wrankin's Avatar
Old Rotary Dog
Does Pineapple (or anyone else for that matter) have actual dyno data on the difference between running with their sleeve/insert versus no sleeve at all? I could believe a difference over the stock setup, but I have to wonder about if there is any significant improvement over open ports in the high RPM range.
Just curious,
-b
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
Devon Murray
Sep 25, 2015 09:41 AM
teebeekay
Sep 16, 2015 01:54 PM
