How much boost with these mods?
Old Apr 19, 2002 | 03:28 PM
Cameljoe's Avatar
How much boost should I be seeing with type of mods I have?
Old Apr 19, 2002 | 04:13 PM
Ryde _Or_Die's Avatar
Is your boost gauge not hooked up or are you getting a different amount of boost than you think you should?
Old Apr 19, 2002 | 04:50 PM
Cameljoe's Avatar
I'm seeing 12 psi in second and 15 psi in third from my boost guage. Stock I'm supposed to see around 5-5.5 psi right? With the DP and silencer according to RB website I should see an additional 1-2 psi. That should be around 7.5-8 psi. right? I have a POS autometer guage but I never heard of them being off by 7 psi. I also stripped one of the nuts that hold the DP to the turbo. Anyone happen to know what diameter and pitch those nuts are?
Old Apr 19, 2002 | 04:55 PM
So you have the stock catback then? As I understand it you should see around 9-10psi with Intake/DP/MP.
Old Apr 19, 2002 | 05:33 PM
Cameljoe's Avatar
Yeah I'm still running the stock catback system for the time being.
Old Apr 20, 2002 | 01:22 PM
Cameljoe's Avatar
Anyone have any ideas?
Old Apr 20, 2002 | 03:49 PM
RETed's Avatar
You're asking us what boost you should be running or what is the max you can run?&nbsp The Walbro will keep the engine happy up to 15psi as long as it gets full voltage!
-Ted
Old Apr 20, 2002 | 04:10 PM
vosko's Avatar
Just Call Me Terminator!
my TII without upgraded ecu with 3" dp and 3" mp hit 7.5psi spiked to 10psi a few times but this is on a 89 TII. 12-15psi sounds normal for a 87 TII
Old Apr 20, 2002 | 05:56 PM
HAILERS's Avatar
HAILERS
I've got a 87TurboII with the 2.5 down pipe and presilencer from Mazdatrix and everything stock from there back. I hit fuel cut on cool days (my guess is 60 degrees and below) which should be 8.6 psi. Today I can't hit fuel cut if I tried.Its in the 80's. I have a Autometer boost gauge. At one time it was showing me hitting 10psi and I was pleased as punch til I started wondering why I had not hit fuel cut. Determined the Auto meter was off 2 to 2and one half. When I hit fuel cut I peg the factory gauge, but then again, with the key to ON, it isn't hitting the zero mark. Its three quarters of the way b/t -20 and zero. The volt meter that is picking the voltage off the pressure sensor says 3.6 something volts when I hit fuel cut on cold days. So the real reason you wrote is to find out what the nut size is on the back of the turbo???? I measure the nut being a M10...1.5. Pepboys should have one or two. Or did you mean the stud that screws in the manifold???? One of three?
Old Apr 20, 2002 | 07:23 PM
Scott 89t2's Avatar
SOLD THE RX-7!
that seems pretty high with a stock cat back and stock TID... you might have some wastegate problems. try running a new vac line from the turbo to the wastegate.
Old Apr 21, 2002 | 01:38 AM
Cameljoe's Avatar
I wrote because I was under the impression that with the mods I have I should be around 8-10 psi. But I'm at 15 psi. I don't want to blow my engine. The nut I'm talking about are the 3 that hold the DP to the back of the turbo.
Scott: I'll take a look at the wastegate tomorrow. I'll let you know if I find anything.
Ted: 15 psi with the stock ecu and walbro pump is ok? I thought a SAFC or an upgraded ecu and a walbro was needed if you wanted to push 15 psi safely.
Old Apr 21, 2002 | 04:28 AM
BoostedRotors's Avatar
I HATE sleepy eyes
I believe the reason youre seeing such high boost is from running a better flowing exhaust and a stock wastegate with no fuel mods other than your walbro. In order to stop this youll need some form of fuel controller or a bigger wastegate...if im wrong, someone tell me.
Old Apr 21, 2002 | 05:33 AM
wai's Avatar
wai
RX7 club knows about you
I have a 3" open exhaust +intake+2.5" custom TID,
my max boost is only 0.35 bar, what happen to my car???
with the boost contoller on , I can run 0.6 or higher...
Old Apr 21, 2002 | 12:00 PM
turbotwista's Avatar
I have racing beat turbo back exhaust and a bonez intake and a walbro and I am hitting 11-12psi in third I have 91'
Old Apr 21, 2002 | 01:26 PM
HAILERS's Avatar
HAILERS
Camel Joe.....I seem to have the same downpipe that you do and the presilencer. The only difference is the K AND N filter. Plus I had the turbo rebuilt by MAJESTIC in Waco, Texas...When they did the rebuild he did say something about some upgrade, but that went in one ear and out the other. Possibly they opened the wastegate hole. Anyway I get what Mazdatrix advertized, about 8 to 9 psi on a cold day but no more than about 8 on a eighty degree day. Autometer gauge is not a bit accurate. I must have bought the only one that they ever made defective. The nut is as described in my above post. Pepboys.
Old Apr 21, 2002 | 02:43 PM
vosko's Avatar
that's normal
Old Apr 21, 2002 | 07:38 PM
HAILERS's Avatar
HAILERS
Cameljoe....... I am confused...again. On another post I see where you talk about how the downpipe flange is busted and the way I understand it, the downpipe isn't connected to the rest of your exaust system. Is this a right assumption?????? If so, I can understand how you are managing to boost so much higher than my car. Surely I misread the other post.
Old Apr 22, 2002 | 10:32 AM
Cameljoe's Avatar
The stock DP (precat) has a flange on both ends. Well the rear flange that you screw 2 bolt through to attach it to the flange of that straight pipe that bolts to the main cat? Well the welds on the flange broke off from the DP (precat). So basically i was driving with an open exhaust. With the exhaust like that I would boost to 8 psi in all gears. This was during this last winter. Just last month my boost has gone up to 15 psi with the same broken/open exhaust. Now I have the RB 2.5" cat replacement pipe I'm still boosting 15 psi. I think my I have a problem with my wastegate. The wastegate has a spring that is rated at a certain psi and also has a vacuum line that helps compress the spring. Am I right on this? Maybe I'm not getting vacuum to the wastegate and I'm just using the spring which is why I'm boosting so much higher?
Old Apr 22, 2002 | 10:36 AM
vosko's Avatar
the wastegate doesn't have a spring because its internal on stock turbos. external wastegates you can change the spring for different boost pressure.
Old Apr 22, 2002 | 05:17 PM
RETed's Avatar
Right and wrong...
The spring is not built *into* the turbo itself, but the wastegate actuator *attached* to the turbo has a spring.
-Ted
Old Apr 22, 2002 | 06:34 PM
vosko's Avatar
ooops my wastegater actuator is adjustable..... i need to get the garrett turbo rebuilt cheap
Old Apr 22, 2002 | 07:16 PM
KenshinFC's Avatar
you might want to be careful. I have bascially the same mods but if you don't have upgraded injectors (720cc), then you could be leaning out the engine when you boost too high. I'm sure I don't have to tell you when you lean it out. But somewhere between 9-13psi sounds right. You may want to get a boost controller.
mulcryant
Sep 9, 2015 05:24 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
gabescanlon
Sep 5, 2015 12:09 AM
