air pump question - to many "air pump" in search
Old Apr 19, 2002 | 11:54 AM
PraxRX7's Avatar
I have an '89 Turbo II, is the Air Pump good for ANYTHING besides the catalytic converter? The bearings are going on it and I want to remove it.
Old Apr 19, 2002 | 12:02 PM
rico05's Avatar
WTB S5 N/A FC
No auxillary ports=no reason to keep it. With a TII, all it does is supply air to the cats. Pull it.
Old Apr 19, 2002 | 12:12 PM
PraxRX7's Avatar
Thumbs down ...
Its as good as pulled.
Old Apr 19, 2002 | 12:14 PM
rico05's Avatar
WTB S5 N/A FC
It is easy. 2 bolts and a belt. Takes 10 miutes.
Old Apr 19, 2002 | 12:21 PM
PraxRX7's Avatar
hmmm...
I noticed that the belt overlaps another pully on the right (facing engine compartment).
Is that a big deal or not?
(The belt seems to span from the airpump, past a main pully, and over what looks like a power steering pully or something.)
I think I will just make sure that the other pullies all still have belts attached.
Old Apr 19, 2002 | 12:29 PM
rico05's Avatar
WTB S5 N/A FC
I just cut the belt, as I have an extra set of em.
Old Apr 19, 2002 | 12:31 PM
PraxRX7's Avatar
Talking
I like that plan =)
Old Apr 19, 2002 | 12:32 PM
rico05's Avatar
WTB S5 N/A FC
I knew ya would!!
Old Apr 19, 2002 | 01:02 PM
ianbell's Avatar
Yeah, and Mazda spent the money to put an air pump on a car just 'cause they had some laying around - it has a function, my friend!
Old Apr 19, 2002 | 01:10 PM
PraxRX7's Avatar
hmmm...
Yea, but without catalytic converters, what the point of having it? If there are lines that I can visibly see going to anywhere else other than the catalytic converter, then I will just remove it air-pump all together.
Cheers!'s Avatar
Former Rx7 *****
if you are keeping the cats and you toss the airpump you going to have a non working cat pretty soon
Old Apr 19, 2002 | 01:12 PM
PraxRX7's Avatar
nope...cats are coming off
The cats are off as of tonight.
Old Apr 19, 2002 | 01:15 PM
Samps's Avatar
I helps pass emissions! outside of that; I'm not sure it does anything to aid in the performance of a turbo 2. The pulley you are refering to is the water pump. And it is a concern if you track race the car due to the belt slipping on the water pump pulley since the contact area of the belt on the pulley is reduced to a mere inch or so. If it is just street driven you should be fine. It may slip for a second at high rpms but unless you drive around at 6-7000 rpms for long periods of time then don't worry about it. If it bothers you get the dual alternator pulley and play it safe. This will let you run two belts over the pullies to increase the contact area. The alternator pully is cheap, and if ya got some extra change I would get it.
Old Apr 19, 2002 | 01:16 PM
Mark S's Avatar
Re: hmmm...
When you remove the AP, you also remove one of the belts that goes around the water pump. At high RPM it can slip and cause the cooling capacity of the car to be reduced.
Do a search on dual alternator pulley, there are several available.
Old Apr 19, 2002 | 01:19 PM
PraxRX7's Avatar
thanks
Thanks...I had seen dual alternator pully stuff on here before relating to the air-pump, I just wanted to double check.
Old Apr 19, 2002 | 01:39 PM
SureShot's Avatar
Seduced by the DARK SIDE
Next time the turbo is off you can now pull & block off the ACV, along with it's outlet pipe & muffler. That will really clean it up under there..
Old Apr 20, 2002 | 12:12 AM
NZConvertible's Avatar
I'm a boost creep...
There's no need to remove the turbo! The ACV is easily accessible for removal. To get to the relief air silencer you just need to remove the RHS brake duct.
For anyone interested a did a quick how-to on this thread.
Old Apr 20, 2002 | 09:52 AM
hypntyz7's Avatar
FWIW I did the dual atlernator pulley mod this week. I got mine form a used repair alternetor/starer shop local. Basically the pulley off any dodge motor with a 2.6 will work..the alternator is way bigger on those cars, but the shaft and offset are perfect. Part number is WAI-24-83100. Basically any dodge 2.6 from 81-87 will work.
BTW I have a spare if anyone';s interested. Ill take $35 shipped for it.
Old Apr 20, 2002 | 11:24 AM
Bambam7's Avatar
I came, I saw, I boosted.
Spare what? Dodge 2.6L engine for 35 bucks?? WAY too much!
j/k
Queppa
Nov 18, 2024 03:47 AM
alphawolff
Nov 17, 2015 05:57 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
