nitrous oxide
Old Apr 19, 2002 | 12:39 AM
crossbar17's Avatar
nitrous oxide
with the mods in my sig and good compression whats a safe number to run on a N2o setup? 50,60,70...could i run a 100hp shot?? and with that and my mods what would my 1/4 mile time approx be?? it is around 14.7-14.9 without the N20
CB
Old Apr 19, 2002 | 12:47 AM
FC3AZ's Avatar
what sig? hahah I think you could easily run a 50 shot, no matter what you have done. If you have a freshly rebuilt motor with 3mm apex seals, you might be able to push 100. I wouldnt do it personally, but, you might be able to pull it off. With a 50 shot, you should be in the 13's if you can control the traction, which is tough with nitrous, because it makes a lot of tq, on top of the 50hp or so.
Old Apr 19, 2002 | 10:17 AM
I wish I was driving!
Re: nitrous oxide
CB
I run a dual stage nitrous system in my car, stage one as a in the TB single fogger and stage two as a driect port injection system into the runners.
I can tell you everything you need to know about running N20 into your Rex, but you need to tell me your mods, and your plans: Kit, brand, accessories...
Sean Cathcart
2 hott
60
Aug 4, 2002 11:15 AM
DELTA_Rotary
Rotary Car Performance
May 3, 2002 11:26 AM
seeer135
Apr 28, 2002 08:43 PM
Greg
Jan 9, 2002 10:17 AM
