aftermarket steering wheel install
Old Jan 24, 2008 | 11:07 AM
Smitter's Avatar
94 Single Turbo FD
ok guys need some help with these 3 things:
1.need help hooking up the horn.
2.can i still hook up my cruise control somehow?
3. how do u get the air bag light to stop blinking?
Old Jan 24, 2008 | 11:09 AM
Smitter's Avatar
94 Single Turbo FD
here's a pic of the wiring harness for the wheel but it needs to be removed for installation
Old Jan 24, 2008 | 11:27 AM
Mahjik's Avatar
Mr. Links
You just need to extend the wiring to the horning wiring. What aftermarket hub are you using?
Sure, you'll have to create something to mount the buttons and then do the wires.
https://www.rx7club.com/showpost.php...33&postcount=3
Old Jan 24, 2008 | 11:32 AM
Smitter's Avatar
94 Single Turbo FD
its a momo hub. not sure of the part # but i believe it is the only one available for the fd.
do i need to use the wiring harness pictured above then?
Old Jan 24, 2008 | 11:44 AM
Mahjik's Avatar
Mr. Links
It would probably be easier to use the connectors and then do your custom wiring.
Here's some info on other people who retained cruise control with aftermarket wheels:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/moving-stock-steering-wheel-closer-possible-ideas-501465/
Old Jan 24, 2008 | 12:10 PM
Smitter's Avatar
94 Single Turbo FD
ok thx mahjik. i will see what i can do here
Old Jan 24, 2008 | 12:31 PM
money's Avatar
John Dillinger
mahjik is the man. follow it, you will get it done!
Old Jan 24, 2008 | 01:52 PM
Smitter's Avatar
94 Single Turbo FD
check this link out for the resistors and tell me if i got the right ones?
http://www.radioshack.com/product/in...entPage=search
Old Jan 28, 2008 | 11:25 AM
Smitter's Avatar
94 Single Turbo FD
Mahjik.......where are ya?
Old Jan 28, 2008 | 11:53 AM
Mahjik's Avatar
Mr. Links
I don't know for a fact that it's the "right" resistor. The hub I'm using (Daikei Miata Hub) came with a resistor already wired to remove the airbag light. I would give it a shot and see if it takes care of the problem. It will be an easy test (and resistors are cheap).
Old Jan 28, 2008 | 12:24 PM
Smitter's Avatar
94 Single Turbo FD
i'll pick one of these resistors up from the good ol' radio shack and let u know if it works or not
Th0m4s
Feb 26, 2019 02:04 AM
