Who has made 600whp on a stock engine?
Old Jan 23, 2008 | 03:38 PM
TehMonkay's Avatar
Back in the game
I know there was at least one person on here, but i cant find the thread, who did 600whp with stock ports stock engine. Anyone else made 600+whp with just porting alone and nothing else?
Old Jan 23, 2008 | 03:54 PM
680RWHP12A's Avatar
the question is for how long did the stock motor make 600 hp...
check with 13B-RX3
Old Jan 23, 2008 | 04:19 PM
AnthonyNYC's Avatar
Stay tuned...
What do you mean by "nothing else"?
Old Jan 23, 2008 | 04:28 PM
crispeed's Avatar
'Tuna'
No rods, pistons etc.
Old Jan 23, 2008 | 04:35 PM
Gorilla RE's Avatar
GorillaRaceEngineering.co
Oh I get it.... Like on stock fuel syst., stock exhaust, stock turbos, stock ign., stock intercooler etc. Sure makes sense to me.
-J
Old Jan 23, 2008 | 05:58 PM
pwwatkins's Avatar
Supra Smasher
I've seen a little over 500rwhp on stock ports.
Old Jan 23, 2008 | 09:02 PM
ErnieT's Avatar
Living life 9 seconds at a time
You can do it, but why? Your powerband would totally suck.
Old Jan 23, 2008 | 09:29 PM
13B-RX3's Avatar
7s before paint!!!
I don't think the powerband would be that bad with the right setup.
Old Jan 23, 2008 | 10:34 PM
t-von's Avatar
Rotor Head Extreme
Internally on a 13brew there isn't really a limitaion at that level. These blocks have the extra casting around the dowel areas to make the engine more solid. I'm not sure about the FC 13bs. You mainly need enough fuel, enough air flow, and a spot on tune. An unported engine will need more boost to achieve what a ported engine would do at lower boost because the non ported engine will be less efficient at moving air through it.
Old Jan 24, 2008 | 05:13 PM
dhahlen's Avatar
FD Under Construction =P
More restriction = Less Efficient?!?!?!? NO WAY!!!
You mean to tell me I've been losing power by FILLING in my ports all these years?!? No wonder my builder looks at me like an idiot when I ask him to fill them in!!
Old Jan 24, 2008 | 06:50 PM
jacobcartmill's Avatar
just dont care.
monkey,
so uhhhh... porting or stock ports?
Old Jan 24, 2008 | 06:58 PM
Viking War Hammer's Avatar
*** Bless The USA
i made 603 whp on the stock motor, all I did was take a roto-rooter to the intake ports
Old Jan 28, 2008 | 01:26 PM
TehMonkay's Avatar
Back in the game
I mean no other internal modifications other than porting like clearancing, balancing, different apex seals, upgraded bearings dowelling etc.
Thank you for your sarcasm.
Old Jan 28, 2008 | 01:44 PM
Gorilla RE's Avatar
That contradicts your original post.... Instead of getting upset for people being "sarcastic", you should have been more specific with your question. Or just search for the answer because its all over this forum.
-J
Old Jan 28, 2008 | 02:39 PM
TehMonkay's Avatar
Back in the game
-J
I know i've seen a thread where someone made 600whp on a completely stock engine. I just couldnt find it. Thats the main reason for making this thread.
Also I wasn't getting upset. I don't get upset over internet sarcasm, unless I don't pick up on it.
Also, I said 600whp on a stock engine, not a stock fuel system, or turbo, or exhaust etc.
But thanks for your help anyway.
Old Jan 28, 2008 | 02:52 PM
Gorilla RE's Avatar
I was talking about the fact that in your first post you said "stock" ports and then in post #13 you said "other than porting"....
Old Jan 28, 2008 | 03:18 PM
mr2foryou's Avatar
600+rwhp club member
Other than porting, my "engine" is stock.
Dee E.
Old Jan 28, 2008 | 04:29 PM
13B-RX3's Avatar
7s before paint!!!
Stock ports could do it assuming that everything (clearances) is right inside the motor. I have heard that doweling/studding isn't mandatory till you go over 700 hp. But then again i am sure the tune has EVERYTHING to do with that.
Old Jan 28, 2008 | 07:10 PM
BluRR's Avatar
Dee E.
Stock seals, shaft and no fancy balancing work?
Old Jan 28, 2008 | 07:31 PM
ErnieT's Avatar
Well, other than porting, my engine is stock too. This thread is pointless. If your motor is out and you want more power, why the hell woudn't you port it?
Old Jan 28, 2008 | 10:13 PM
Viper GTSR's Avatar
Performance Veteran...
Ernie, you made the 752rwhp on the stock seals and completely stock E-shaft?
Old Jan 28, 2008 | 11:40 PM
mr2foryou's Avatar
YES, that is correct. Stock seals, E-shaft, rotors, housings, irons. Everything.
Dee E.
Old Jan 28, 2008 | 11:44 PM
crispeed's Avatar
'Tuna'
Why would you need something different?
I've seen way higher power with the same.
Old Jan 28, 2008 | 11:47 PM
680RWHP12A's Avatar
same here, dam noobs!!
Old Jan 28, 2008 | 11:55 PM
crispeed's Avatar
'Tuna'
Nah!
We're just to old at ths game.
