O2 sensor?
Old Apr 18, 2002 | 03:31 PM
O2 sensor?
Well there I was trying to find the cause of bad idle. When I look down at the O2 sensor, it's wire was tucked behind my engine. Yup not hooked up at all. So now I have to find the other end. I have looked many times and found nothing. Can someone tell me were the O2 sensor wire normally routes in the engine compartment. PLEASE. I have also looked through my haynes manual, which turned out to be a waste of time. I would really like to fix this problem, so if some one could help me out it would be greatly appreciated. Thanks.
1987 turbo 2
Old Apr 18, 2002 | 03:38 PM
jmseven's Avatar
Asset is Wealth
From the main harness the wraps around the passenger side of the engine, behind the filler neck, you should see a single "black" wire. That IS the wire for the O2.
Old Apr 18, 2002 | 03:39 PM
HAILERS's Avatar
HAILERS
O2 sensor is out of the loop at idle. Sorry 'bout that. The wire on the sensor goes to a connector and its wire which run under the intake, goes to the drivers side of the engine, routes around the front of the engine, crosses over to the passenger side fender, goes aft and enters the crew compartment. and ends up at pin 2D of the ECU that is under the rug about where the ***** of the passengers feet are. Its the middle plug. With the plug connected and looking towards the ECU, pin 2D is on the bottom row, second one from the left.
Old Apr 18, 2002 | 03:40 PM
Pinfield357's Avatar
mine and yours (we nave the same car) plugs in right behind the intercooler piping. it is actually located right behind and under the rubber elbow on the top of the piping. hope this helps
pinfield
Old Apr 18, 2002 | 03:41 PM
HAILERS's Avatar
HAILERS
Make that the second pin from the RIGHT, please. Typo.
Old Apr 18, 2002 | 03:55 PM
Thanks alot guys. Thats a big help.
Old Apr 18, 2002 | 04:27 PM
I found the wire but it is brown not black. Why? Different engine harness? I don't know.
Old Apr 18, 2002 | 04:30 PM
It is totally freaking me out. What has happened to my car? What has some one done? It looks pretty "mickey mouse" to me.
Old Apr 18, 2002 | 04:57 PM
HAILERS's Avatar
HAILERS
The original 02 wire is supposed to be grey. It should be a shielded wire. The inner conductor probably is black, I forget if I ever knew. The shield terminates about six inches from the 2D, ECU pin. Where it enters the ECU, it is black, I believe. Oh. The grey wire turns brown over the years. Your car sounds normal to me.
Old Apr 18, 2002 | 05:44 PM
VashtheStampede's Avatar
if you are crimping a new O2 sensor on there (on the braided side) make sure the braid is NOT touching the inner wire or connector or it will not work properly.
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
