Buzzer locations?
Old Apr 18, 2002 | 11:41 AM
1FastT2's Avatar
Buzzer locations?
I am wondering where all the buzzers are under the dash? I want to remove them. I am now running a Haltech and dont need them. There going off all the time and im going to take my first ride in it tonight and dont want to put up will all of that buzzing in my ear.
Thanks,
Brian
Old Apr 18, 2002 | 01:41 PM
1FastT2's Avatar
BUMP
Old Apr 18, 2002 | 02:01 PM
Flyby116's Avatar
Think its right behind the gauge cluster.
Old Apr 18, 2002 | 02:10 PM
darkwaveboi's Avatar
Need donor car in Fairfax
the one that beeps for the seatbelt (when u turn the ignition to on) seems to come from around the fuse box...not sure though. It stops when you unplug the 'room' fuse....thats about all the info i can submit
(the beeping is the same as the one that sounds when you open the door and your lights are on.
Old Apr 18, 2002 | 02:12 PM
Josepi's Avatar
Despise Enmity
What else is on the room fuse? Mine doesn't ding when the doors are open/lights on. It sucks when I walk 40 feet away and look back to see my running lights are on.
Old Apr 18, 2002 | 02:30 PM
when i pulled it i got: no beeping from door/seatbelts, door lights (when doors are open), dome lights, clock/dummy lights, stereo, bin lights, glove box light. I think thats it. I dont think that the room fuse effects the logicon lights (it might though). doesnt effect the instrument panel either im pretty sure.
taking it out basically kills all the 'unnecessary' things inside the car..you'd notice if it were blown.
Im still trying to find out where the sensor is on the auto seatbelts that makes the beeping noise (top of shoulder strap, bottom; left side lap belt, or right side)...
once i find that bastard its getting cut
Old Apr 18, 2002 | 02:39 PM
Josepi's Avatar
Despise Enmity
Shitty, I still get my interior lights, just no noise.
Old Apr 18, 2002 | 02:40 PM
maybe the beeper/speaker is broken...?
Flyby116's Avatar
Sorry thought you were talking about the buzzer that goes off on redline not seatbelts lol
Old Apr 18, 2002 | 02:42 PM
i still dont know whether or not he was talking about the redline buzzer or the beeper...they sound completely diff
Old Apr 18, 2002 | 02:57 PM
rotorhead1's Avatar
i too, would like to remove my redline buzzer that starts going off 1500 rpms before redline.
Old Apr 18, 2002 | 04:19 PM
NZConvertible's Avatar
I'm a boost creep...
I’m not sure why you’d want to disable all your warning buzzers just because you’re running a Haltech. A Haltech won’t tell you you’ve left your lights on or you’re low on oil!
For those who’s aren’t working, most are in the CPU, beside the fuse box. The FSM has diagrams showing what systems are where on the circuit boards. There seems to be a different beeper for each warning, because my “keys in/door open” beeper always works but lights on/door open” one only works occasionally. I’m sure it’s just a loose connection, but it’s not very loud anyway, so instead of fixing it I made my own one that’s much louder and more annoying!
Old Apr 18, 2002 | 04:25 PM
bravebluerx's Avatar
bravebluerx
If you are referring to the seatbelt beeping when you drive:
If you car has the automatic seatbelts, take off your center arm rest console to find the seatbelt retract housings. The back part of the housings are plastic and contain circular sensors which wear down. To verify this is this problem, Pop these plastic housings off carefully with a small screwdriver. When one of the seatbelt moves a little on this worn circular sensor it will cause the beeping. These circular sensor wires connect to a plug (under the security light/change holder plate). Unplug the seatbelt connector there and then get two jumper wires with slide in male ends and plug these in instead of the seatbelt wires. If the seatbelt beeping is still present you may have cold solder points in your cpu that need resoldering.
You could always buy new circular seatbelt sensors from the dealership too if you had money to burn Or if you didnt want to use the jumper wires.
Old Jun 2, 2004 | 01:21 AM
RevinRx7's Avatar
Concerned Citizen
Yeah I'm having the same freaking problem. I've swaped an RE motor in and gotten rid of the warning lights and cut the buzzer wire behind the gauge cluster and it still beeps. Shoot i don't remember now. I'm almost positive its not the coolant level buzzer. Does a buzzer/beeper go off when the electric fan on the TII goes on? any ideas PLEASE i'm going to shoot my car soon cause its SOOO anoying.....
Old Jun 2, 2004 | 03:46 AM
Kenteth's Avatar
Like Ghandi with a gun
why, hell i can bearly hear mine over teh exuast, I'd want mine louder
Old Jun 2, 2004 | 07:42 AM
Icemark's Avatar
buzzer (the only one) in the CPU reports:
door open key on
door open lights on
seat belts
Buzzer in gauges reports
oil level low
coolant level low
RPM over redline
beeper in power steering computer reports:
problems with power steering system
and on convertibles
beeper in rear reports:
Top motor operation
parking brake not on and attempted top operation
Old Jun 2, 2004 | 01:05 PM
RevinRx7's Avatar
Concerned Citizen
[/B]
I bet thats it Thanks
Old Jun 2, 2004 | 07:01 PM
Icemark's Avatar
That is in the FAQ for FC at the top of this section!
Old Jun 2, 2004 | 10:18 PM
Kenteth's Avatar
NZconvrtible, how'd you wire the secondary buzzer (louder)?
Old Jun 3, 2004 | 06:53 AM
For the headlight warning? Just get a piezo buzzer that you think will provide sufficient warning, tap its positive wire into a taillight wire (red/black) and its negative wire into a door switch wire (blue/white). The buzzer will sound any time the headlights are on and you open a door.
http://www.autospeed.com/cms/A_0848/article.html
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
