So... does anyone here with +400 whp NOT blow smoke at WOT?
Old Jan 13, 2008 | 11:41 AM
s-thetikz's Avatar
4 rotor 964 lol
Why hallo thar.
So I'm wondering if you big ballers out there (to be honest, I wanted to route this thread towards those with single turbos) not blow smoke at WOT ? I'm always weary of stomping the pedal because of the obscene amount of smoke that I'm blowing at full acceleration.
I've seen extremely reliably built supras blow massive amounts of smoke in the same situation, and turbo cars in general seem to be plagued by this. How have you quelled this , if at all? I don't have any emissions on the car, and I also wonder if the hi-flow cat waffle shaking around (from being burned loose) contributes to this with the high heat.
Old Jan 13, 2008 | 01:39 PM
G's 3rd Gen's Avatar
If the car is healthy it will be the richness of the aka fuel smoke. Depending on how good of a tune you have. Built turbo rotaries see this quite a bit as most tune on the rich side to counteract detonation.
Old Jan 13, 2008 | 01:40 PM
PDViper77's Avatar
HAHA V8
nope!!!
Old Jan 13, 2008 | 01:46 PM
FD3S-K's Avatar
Geby
not at all.
Old Jan 13, 2008 | 02:51 PM
Smitter's Avatar
94 Single Turbo FD
no smoke here either...........maybe u have a problem with your turbo feedline restrictor and oil return. make sure your crankcase is properly ventilated
Old Jan 13, 2008 | 06:19 PM
pp13bnos's Avatar
Pineapple Racer
Video of my FD shows a bit of black smoke, due to a slightly over rich tune. No smoke though. CJ
Old Jan 13, 2008 | 09:11 PM
pwwatkins's Avatar
Supra Smasher
+1
Old Jan 14, 2008 | 11:09 AM
EZFD's Avatar
I get a little bit, but not like plumes of billowing smoke. If the car is tuned safely (slightly rich) it will naturally smoke a little more than usual, also if you premix it will smoke too. just my $0.02.
Old Jan 14, 2008 | 12:11 PM
arghx's Avatar
rotorhead
crankcase ventilation and richness of mixture
Old Jan 14, 2008 | 12:15 PM
Viking War Hammer's Avatar
*** Bless The USA
only from the tires
Old Jan 16, 2008 | 06:54 PM
justturbo2's Avatar
Registered User
[QUOTE=Viking War Hammer;7737619]
only from the tires
+ 2
Old Jan 16, 2008 | 07:53 PM
IAN's Avatar
IAN
Rotary Reborn!
No smoke here.
Old Jan 17, 2008 | 06:40 AM
coxxoc's Avatar
Shooting for 500
Only after shifts, a black poof. Rich and I need better venting.
Old Jan 17, 2008 | 10:46 AM
sk8world's Avatar
Chasing numbers
Originally Posted by pwwatkins
+1
Sounds like you are having more than the normal richness most run. I Bet your anwser has been posted above already! (crankcase venting) Happened to me when I first went single.
ls1swap
Jun 3, 2024 03:25 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
