FD short throw shifter
Old Jan 11, 2008 | 07:20 PM
bsj44's Avatar
CA FD short throw shifter
Hi,
Will somebody give me the procedure to replace the stock shifter into a short throw one and what brand to use for extended reliability.
Old Jan 11, 2008 | 07:31 PM
RX7LINK's Avatar
RX7FD3S
procedure is uber simple:
1. twist and remove shift ****
2. lift up shifter console plastic
3. remove bolts related to shifter
4. replace shifter
5. put console and shift **** back.
extended reliability? u mean.. like a product warranty?? short shifter's very unlikely to break. but they're intended for offroad use. use at your own risk. different folks different stroke. I would do a search to see people's responses and decide out of the name brands for yourself.
Old Jan 11, 2008 | 08:08 PM
Sgtblue's Avatar
Urban Combat Vet
Originally Posted by bsj44
......and what brand to use for extended reliability.
Search in titles only using terms like "short" or "shifter" and you should get some good results.
As far as I can tell, there are two basic designs...The 'Cs', B & M; GOTHAM style design and the MAZDASPEED; PETTIT; RX7store designs. Each have they own sets of advantages but I think all are generally good quality.
FWIW, I'm happy with my PETTIT.
Old Jan 11, 2008 | 08:25 PM
Busted7's Avatar
Will work for horsepower
Be sure to check the plastic ball cap on the end of the shifter and make sure its good. Plus put trannie fluid in from the top to lube the shifter. I have b/m its also good.
Old Jan 11, 2008 | 11:07 PM
moconnor's Avatar
http://www.mazdatrix.com/faq/ssinstal.htm
swif's Avatar
Almost back together
I had a RE-A and I am running a Mazda Speed short shifter. I like the Mazda Speed for how short the throw is. Also as far as the as the plastic ball cap Mazda Trix sells a brass one. They also have an instruction manual to down load I think. Very good. I mentions some parts that should be changes at that time do to breakage from old age.
Also search the forum. Many have their thought because tat is wat they run. I like the feel of both the RE-A and the Mazda Speed, but I wanted the throw of the MS because of how short is is.
Old Jan 12, 2008 | 12:50 AM
shifterkartracer's Avatar
https://www.rx7club.com/showthread.p...t=ebay+shifter
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
