side seal ?
Old Apr 17, 2002 | 05:26 PM
Brian P's Avatar
side seal ?
Ok, I'm going to be rebuilding a 90 n/a engine. I'm looking in the parts manual and there are different side seals for turbos and n/a's.. Whats the dif? rotors different or something? This car *might* be getting a turbo put on in the future (vert) so should I go with the turbo seals or stick with na ones?
Old Apr 17, 2002 | 05:30 PM
Brian P's Avatar
ok, turns out there are alot of parts that are different... like apex seals, side seals etc....
Whats the diff?
Old Apr 17, 2002 | 06:51 PM
HAILERS's Avatar
HAILERS
http://www.mazdatrix.com/b3.htm
Old Apr 17, 2002 | 06:56 PM
dre_2ooo's Avatar
The internals of the TII engine are lower compression rotors b/c of forced induction. The N/A's had higher compression (larger) rotors. It'd be safest to go with the parts built for the car AND year (86-88 is different from the 89-91, 89-91 had lightwieght rotors and more durrable parts (durable in the fact that its reline is higher).
Old Apr 17, 2002 | 07:24 PM
j9fd3s's Avatar
Community Builder
the difference is in the coating. use 93+ cornel seal springs they are a lot better.
mike
Th0m4s
Feb 26, 2019 02:04 AM
Snoopy FD
Dec 8, 2015 01:45 PM
sYnth.
Aug 19, 2015 06:27 PM
