Sponsored by: CARiD
HI , i need advice on fd3s
Old Jan 9, 2008 | 07:34 PM
David0ff's Avatar
Hi guys , name`s David , im plannng on buying a JDM FD really soon ,
im mostly a BMW and honda guy and i know my way around a car / engine etc ,
I am very new to the rotary scene and i would apreciate any pointers i can get on what to look for when purchasing an FD
today i have seen 5 different FD`s all with different level of mods to them but i found a semi-stock one ( spring / apexi filters only )
it does not smoke on start , unlike most of the other ones , and i started it fresh off the container ( outside temp ~ 2 degrees celsius )
~ 130xxx km`s ( is that high for an FD?)
runs smooth , very quick spool on the turbo , suspension / steering very strong ,
minor oil pan gasket leak ( gettign fixed ) and there is a sensor ( oil pressure ????) above the 2 front spark plugs which is leaking a bit ( getting swapped form another engine )
once on the lift and left on , ( also noticed when a car is on the floor ) , there seems to be some repetitive particular noise ( sort of a weak waek , cant describe it , thomping ... knocking cylinder noise from piston engines ) , was present on all 4 other fd`s , ... tat was coming for more the tranny area than the engine ,
btw what is the air pump good for ? emission ?
can i use full sysnthetic 5w-40 mobil 1 for gasolines engines in it ?
any .. i mean any tips / comments are much apreciated
thx ... and .. hope you enjoyed the read
Old Jan 9, 2008 | 08:41 PM
mikewoodkozar's Avatar
Brap, Brap, Ole!
In the 3rd gen section i think there is a post that walks you through all of the stuff to look/lookout for when buying an FD
Old Jan 9, 2008 | 09:11 PM
Mahjik's Avatar
Mr. Links
Arrow
http://rx7.voodoobox.net/infofaq/bguide3g/bguide3g.html
Also check the 3rd Gen FAQ:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/faq-3rd-gen-other-useful-links-68640/
Old Jan 9, 2008 | 10:31 PM
David0ff's Avatar
thx guys
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
cto_2
19
May 8, 2018 08:15 AM
Zinraf
Oct 1, 2015 01:09 PM
