Turbo timer installation?
Old Apr 17, 2002 | 11:26 AM
Ryde _Or_Die's Avatar
Alright, well I finally got my TT in today. Its the Apex autotimer. There are no english instructions but it has pics of ecus to choose from depending what car it is going in. So I take it I have to plug it into the ECU. I thought there were wires under the steering wheel that I just splice into but I guess not. And it looks like on my 87TII the ground wire goes on top of the O2 sensor wire(image is really blurry). If anyone has some good english instructions or knows how to do this please let me know. Oh and pics would be nice Thanks.
Old Apr 17, 2002 | 11:35 AM
Ok coming from the turbo timer there is a harness(which I know goes into the wiring harness) and there are three wires. A white with red stripe, black with red stripe, and gray with red stripe. Where do these go to? Also on the wiring harness there are 2 "wires"(very short), one red and one green. They have some sort of ends on them that look like they plug into something. Anyone know what all of this is? Thanks alot.
Old Apr 17, 2002 | 04:58 PM
NZConvertible's Avatar
I'm a boost creep...
Re: Turbo timer installation?
ALL turbo timers are basically wired in parallel with the ignition switch. This means you will need to get to the ignition switch wiring under the steering column. It sounds like you have a direct plug-in harness, so that shouldn’t be too hard. The wire that goes to the ECU is probably just an rpm signal.
Why the hell are you anywhere near your O2 sensor?! That has nothing to do with a TT! Normally the TT’s earth can just go onto a handy screw or bolt wherever the unit is mounted.
If you can’t figure this out, take it to someone who can translate Japanese or who has actually installed on of these.
Old Apr 17, 2002 | 05:11 PM
Icemark's Avatar
Re: Re: Turbo timer installation?
actually a couple of the newer ones monitor everything from mixture/lean/rich, to RPM, to redline as brakes and vehicle speed.
Old Apr 17, 2002 | 05:43 PM
Re: Re: Re: Turbo timer installation?
Ah yeah, forgot about that! In that case a thorough study of the ECU wiring diagrams might help figure out what's in the TT's manual. Someone who can read Japanese would also be invaluable!
Old Apr 17, 2002 | 06:05 PM
I think I figured it out except I need to look at the ECU to figure where the ground and the O2 sensor wires go. I got everything else though I think. Thanks.
Oh and this TT has a built-in a/f ratio gauge and it can tell how hard the car has been run and keep the car on the proper amount of time.
Old Apr 17, 2002 | 06:22 PM
Yeah, I had a Levoc TT that did that, quite handy.
Get the wiring diagrams chapter of the FSM; page 50-25 shows the ECU with the O2 sensor at bottom left, and the next page shows the plug you want (EM-31, bottom left) with the wire colours. Cakewalk!
Old Apr 20, 2002 | 04:18 PM
Ok is the O2 sensor green with a yellow stripe? Me and Ted came up with that. Now the only problem I am having is that I can't figure out where the single red and green wires go to from the wiring harness.
Old May 7, 2002 | 07:39 PM
LetsGO7's Avatar
hey dudes...what colors are the IG1 output, IG2 output, and 12V+ on the 2nd 87 turbo? Thanks
Old May 7, 2002 | 08:57 PM
The ignition key wires:
B (+12V) is black
ACC is blue
IG1 is black with a white stripe
IG2 is black with a red stripe
START is also black with a red stripe
The TT gets wired across B and IG1. You don't really need to hook up the TT's ACC wire, your radio doesn't require cool-down time...
Old May 7, 2002 | 10:34 PM
Pinfield357's Avatar
O2 wire color
i just hooked up my a/f ratio gauge and also discovered that the FSM said that the wire your looking for was green with a yellow strip but mine turned out to be BLACK.
just letting you know
oh yeah i have an 87 T2
Old May 8, 2002 | 12:00 AM
I wish I was driving!
Is this that tiny pen shized turbo timer they have for $110 or so?
Sean
Old May 8, 2002 | 12:16 AM
Sean
Ya its the small one but its only $85
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
