Manifold dosent fit? (pics)
Old Jan 5, 2008 | 10:06 PM
vr6t3t4's Avatar
anybody ran into this sory to keep blowing up the forum with stupid noob questions but you guys keep answering them.. so yah anybody know?
Old Jan 5, 2008 | 10:11 PM
7passu's Avatar
supra7
try to go straight in with it instead of at a angle....if that doesn'y work, grind the hole out untill it slips on. Also you can tap the studs (with nuts screwed on the ends) inward on one side untill it slips on. Hope this helps
Old Jan 5, 2008 | 10:27 PM
IRPerformance's Avatar
Sponsor
Ebay manifold?
Old Jan 5, 2008 | 10:41 PM
vr6t3t4's Avatar
i just fliped the manifold upside down and it slid right on.
not really happy with a certin seller on here right now...
Old Jan 5, 2008 | 10:55 PM
skir2222's Avatar
I win
Originally Posted by Rotary Experiment Seven
Ebay manifold?
Yea, or the one the RX7store sells in there kits. To the thread starter what kind of turbo are you putting on?
Old Jan 5, 2008 | 11:00 PM
Marshall's Avatar
Chinese manis, FTL. Time to hit the drill press.
Old Jan 5, 2008 | 11:05 PM
CMonakar's Avatar
rebreaking things
Looks like the ebay Fujita copy. A friend and I bought them awhile ago. The flanges for both were warped. We took them to a machine shop and they flattened them out for about $40 each.
Old Jan 5, 2008 | 11:07 PM
Mahjik's Avatar
Mr. Links
Arrow
I'm assuming it's this setup:
https://www.rx7club.com/showthread.php?t=665941
Old Jan 5, 2008 | 11:13 PM
vr6t3t4's Avatar
god damn it. where can i get a good manifold that will fit my wastegate and work with my gt40 turbo it has a t4 flange...
god am i pissed.
Old Jan 5, 2008 | 11:28 PM
Busted7's Avatar
Will work for horsepower
Are you saying it has a t3 flange? And if you grind the bottom of the flange to motor were tension bolts go it will clear better. Also i recomend getting shorter studs as the shoulder of the stock studs prevent it from tightining up well unless you use washers but i dont like that. I here your frustration!
Old Jan 5, 2008 | 11:33 PM
Jason's Avatar
The one
Never seen one of those manifolds not fit. Just open the holes up a little.
Old Jan 5, 2008 | 11:35 PM
vr6t3t4's Avatar
no they welded the flange that bolts to the motor upside down so if you flip the manifold up sidedown it fits.
Old Jan 5, 2008 | 11:37 PM
Jason's Avatar
The one
There really shouldnt be a difference. The holes should line up either way.
Old Jan 5, 2008 | 11:40 PM
vr6t3t4's Avatar
there is a difference it matters. they are in different spots
Old Jan 5, 2008 | 11:52 PM
t-von's Avatar
Rotor Head Extreme
Your right....the exhaust exit will be off center. The studs and the exhaust exit in a way that if flipped around, the exhaust exit will be in a different higher position causing more turbulence. You know you could cut the runners and flip the flang so you can reweld it.
Old Jan 6, 2008 | 12:18 AM
vr6t3t4's Avatar
yeah i could but is it really a good idea to chop the **** out of an ebay manifold that may not work anyway.
Old Jan 6, 2008 | 12:22 AM
njstreetrx7's Avatar
Open The Holes Up
Old Jan 6, 2008 | 12:32 AM
vr6t3t4's Avatar
isnt it bad to turn the holes into rectangels?
Old Jan 6, 2008 | 12:42 AM
vr6t3t4's Avatar
would that hks cast manifold work with my setup?
Old Jan 6, 2008 | 12:55 AM
Turblown's Avatar
Turn up the boost
Cast units flow terribly compared to tubular units. If you haven't noticed already, going the cheap route costs you more in the end. Stop screwing around and do it right. If you can't afford to do it right, then you shouldn't be doing it at all...
Old Jan 6, 2008 | 01:06 AM
vr6t3t4's Avatar
than helpme find a manifold thats not 800$
Old Jan 6, 2008 | 03:14 AM
cp1's Avatar
cp1
edit nm.
Old Jan 6, 2008 | 06:30 AM
dgeesaman's Avatar
Not really.
Old Jan 6, 2008 | 08:46 AM
Jason's Avatar
The one
What turbo and wastegate are you running?
Old Jan 6, 2008 | 11:36 AM
darkside7's Avatar
have you tried to contact A-spec?
