Fuel pump pick-up question
Old Apr 16, 2002 | 09:25 PM
SortedDub's Avatar
I'm working on a 13bt 1st gen project which will be making around 450rwhp. I was planning on using the Aeromotive fuel pump which needs a -10 feed line. I still wan't to use my stock fuel tank but it only has a 1/2" pick-up. What would be the best way to run a -10 line from the stock tank?
Old Apr 16, 2002 | 10:48 PM
RETed's Avatar
Hard metal line...
There are tube fittings that'll adapt the hard line to AN fitting.
-Ted
Old Apr 16, 2002 | 11:03 PM
rx7passion's Avatar
i wouldnt recommend using the stock pick up witha aeromotive. use a sump off the bottom if yoru going to do it that way.
Old Apr 17, 2002 | 07:24 AM
amemiya's Avatar
he's right. use a bung. IMHO
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
