Haltech Injector confusion
Old Apr 16, 2002 | 02:14 AM
SPEED_NYC's Avatar
RX-Parts
Injector confusion
I'm a little confused as to what combination of high and low impedance injectors I can run with an E6K. I run 6 injectors in my car, currently 550 primaries, 850 secondaries, and 2x720 aditional injectors.
I'd like to run 4x850cc and 2x1000cc, with 2 of the 850's as primaries and the other 4 acting as secondaries.
I've been told that I can only run a max of 4 high impedance injectors, and that the stock 850's are all high impedance. the 1000's I'm considering are also high impedance. will this set-up be able to work?
do i need to do anything special as far as set-up and settings on the ecu before i start the car for the first time? or do i need a diffrent injector combination?
thanx in advance!!
Old Apr 16, 2002 | 04:26 PM
SPEED_NYC's Avatar
RX-Parts
anybody?
Old Apr 16, 2002 | 11:05 PM
RETed's Avatar
Don't you have a Haltech manual?
The manual clearly states it can only power ONE peak/hold (i.e. low-impedence) fuel injectors PER channel or TWO saturated (i.e. high-impedence) fuel injectors wired in parallel PER channel.
-Ted
Old Apr 17, 2002 | 08:52 AM
SPEED_NYC's Avatar
RX-Parts
thanx for the attitude, and answer Ted. so i'm safe with my current set-up?
btw, i do have the manual, its just that this is my first haltech instal, and electronics isn't my strong point. (i'd rather do an engine swap than a radio or alarm instal)
Old Apr 17, 2002 | 08:55 AM
SPEED_NYC's Avatar
RX-Parts
Old Apr 17, 2002 | 01:23 PM
RETed's Avatar
You scare me!
Trying to tackle a stand-alone EMS install when you're not confident with electronics!
DAYAM, I give you an A for effort!
-Ted
Old Apr 17, 2002 | 03:58 PM
SPEED_NYC's Avatar
RX-Parts
haha, don't be scared, I'm just a speed Junkie on a budget.
I'm a firm believer in: do it cheap, and do it yourself (with a lil help from the forum)
thanx Ted!
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
bryancmatthews
Power FC Forum
Sep 5, 2015 03:57 PM
doritoloco
Sep 5, 2015 12:41 PM
