ELECTRONIC egt gauge?
Old Apr 16, 2002 | 12:10 AM
Ryde _Or_Die's Avatar
Ok what exactly would be electronic about an egt gauge? I mean does that mean it doesn't have a probe or what? I just figured they were all mechanical or whatever.
Old Apr 16, 2002 | 12:44 AM
RETed's Avatar
EGT's normally use a K-type thermocouple, which is basically a thermistor - a resistor that changes resistance depending on temperature.&nbsp To measure this resistance, "meters" typically shoot a voltage into the sensor and record voltage off the other side - by monitoring the output voltage, you can deduce resistance, which in turn calibrate this to a known table of values to which to you can apply to a gauge readout...
-Ted
Old Apr 16, 2002 | 12:46 AM
So electronic egt gauges have probes right? They aren't like hooked up to the stock O2 sensor or ecu or anything right?
Old Apr 16, 2002 | 01:14 AM
Scott 89t2's Avatar
SOLD THE RX-7!
probe, you need another hole in your exhaust.
Old Apr 16, 2002 | 06:38 AM
NZConvertible's Avatar
I'm a boost creep...
Not quite right. A thermistor is, like you say, a resistor that changes resistance with temperature, but a thermocouple is quite different. It actually generates a voltage, caused by two dissimilar metals joined at the probe's tip.
Just keepin' ya honest!
Old Apr 16, 2002 | 01:18 PM
RETed's Avatar
Oops, should've seen that coming - too much Vegas buffet last night!
-Ted
WANKfactor
Sep 15, 2015 07:45 AM
Monsterbox
Sep 11, 2015 03:29 PM
