question about 89-91 manifold..ASAP
Old Apr 15, 2002 | 11:07 PM
mzspeed7's Avatar
will a 89-91 manifold conversion.. still work if i have no emissions .. no air pump .. and my actuater wired open?.. i need to know ASAP
Old Apr 15, 2002 | 11:22 PM
rx-7fc's Avatar
it should i about to put a 89-91 manifold on mine it's a 87 look at the hp numbers on this carhttps://www.rx7club.com/forum/showth...threadid=56672
Old Apr 15, 2002 | 11:23 PM
kleach18's Avatar
Just Looking Around
Pretty sure it would work. This guy I know says he could do it and he knows a sh*t lot about 7's. Every time we open my hood all hes says is that he want's my intake manifold. I got a s5 he's got a s4.
Old Apr 15, 2002 | 11:30 PM
mzspeed7's Avatar
yea im doining the s5 conversion on my s4.. but it will work with no emissions and air pump and my 6ports wired open?
Old Apr 15, 2002 | 11:52 PM
NZConvertible's Avatar
I'm a boost creep...
Without an air pump (and a S5 ECU for that matter) there's nothing to actuate the VDI. This is what gives the S5 a chunk of its extra power over the S4. Plus you'll lose some torque down low beacuse of the aux ports being open. Doesn't sound like much of an upgrade...
You should really consider the electronic aux port actuation method descibed at www.fc3s.org. You could probably actuate the VDI the same way.
Old Apr 15, 2002 | 11:55 PM
mzspeed7's Avatar
well after all that im buying a rpm swtich from summit for 45.95
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
