Rotary Drag Racing The place to post your racing stories and info
And this is how the ROTARY was BANNED FROM NHRA.
Old Dec 12, 2007 | 08:12 PM
Viking War Hammer's Avatar
*** Bless The USA
I had to pull some teeth to get the guy from ESPN (Bret Kepner) to write this little peice on Terry Hoard's 4 Rotor RX3.
Most of you were still in your dads bag when this happened but this is history, folks.
It was Terry Hoard's skill, much more than his RX3, which eventually led to the removal of rotaries from conventional NHRA Drag Racing. Hoard competed in (the original) Modified Eliminator which used indices created by NHRA Tech Officials for handicapping purposes with no breakout enforced. Under normal circumstances, NHRA Tech tried to keep the quickest runs in any given class around one second quicker than the class Index.
Hoard's RX3 originally fit into the C/Modified Compact classification but quickly proved to be much more than a second quicker than the index. The Modified Compact classes included a variety of foreign four-cylinder powerplants. However, NHRA knew revising the Index to fit Hoard's performance would simply obliterate every other car in the C/MC class so they simply moved the four-rotor RX3 combination into B/MC, one class higher.
Hoard destroyed the Index in that class, too, so NHRA moved him to A/MC. He bombed the competition again. By this time, (early 1980), NHRA was finally admitting they had no clue how to accurately classify the Wankel against standard piston-engine combinations other than to throw a ton...okay, maybe a half ton...of weight into the car to slow it down and equalize it with the four-bangers.
Eventually, they put Hoard in the AA/MC class in which he was forced to run against turbocharged four-cylinders, (Buddy Ingersoll's turbo Pinto was the killer at the time), but Hoard had to run without a blower. He still romped.
When NHRA killed Modified Eliminator at the end of 1981, they disseminated all Modified classes into either Competition Eliminator or Super Stock Eliminator. However, the NHRA was so tired of chasing Hoard's Mazda they simply wrote the combination out of the rulebook. To this day, nobody has developed an equitable method of comparing the power potential of Wankels versus piston engines in conventional NHRA racing.
And that, children, is how the Grinch stole Triangles.
Old Dec 12, 2007 | 08:28 PM
rotorholic's Avatar
DPG Burnout
What did the rotaries run in the 80s?
Old Dec 12, 2007 | 08:30 PM
mazda1200's Avatar
this is true history there thanks for sharing with us...
Old Dec 12, 2007 | 08:35 PM
*** Bless The USA
This shot is of Jim Mederer from Oregon winning Modified Eliminator at the 1978 NHRA Winternationals. One year later, Terry Hoard and his Samurai Warrior '77 four-rotor began a string of wins which made sure rotaries were banned from NHRA Drag Racing forever.
Old Dec 12, 2007 | 08:39 PM
crispeed's Avatar
'Tuna'
You know the story about what happened to the 'Samurai Warrior' when he decided to take on the PR crew at the time.
Let's see how far back you go then.
Old Dec 12, 2007 | 08:49 PM
T.MagnumPornStarExtraordinaire's Avatar
The Claps
OLD SCHOOL................
look @ those people.....
with their afros and what not....
That reminds me of vintage ****..um...I mean disco,...
yeah Disco.
Old Dec 12, 2007 | 09:37 PM
rotary8's Avatar
eccentric shafter
yes crispeed he got worked by the puertoricans.
Old Dec 12, 2007 | 09:43 PM
luiml73's Avatar
Rotary Powered Boobies
with a 12a
Old Dec 12, 2007 | 10:45 PM
crispeed's Avatar
'Tuna'
Which one to be exact?
Old Dec 13, 2007 | 06:15 AM
KNONFS's Avatar
B O R I C U A
Vivo Racing?
Old Dec 13, 2007 | 08:16 AM
Judge Ito's Avatar
the original "Loquito" Senor.... Beno Velez
Old Dec 13, 2007 | 08:44 AM
LT1RX7's Avatar
Good work you got bumped from Sportsman index racing against NA 4 bangers in the early 80's......IMPRESSIVE!!!!
Since Demetrious runs NHRA I wouldnt go as far as to say the rotary was "banned from NHRA".
Old Dec 13, 2007 | 10:15 AM
sao1's Avatar
Good read Viking War Hammer... very inspiring.
Old Dec 13, 2007 | 10:37 AM
RoTaRyBoYz's Avatar
InsaneRotaries.com
These guys are speaking about the original NHRA where its mostly a V8 sport... Dee competes in NHRA "sportcompact" which was formed for small displacement motors including the rotary... BTW Dee no longer runs a rotary..
Never knew racing beat's Jim Mederer was into drag racing, all thought those guys were road racers
Old Dec 13, 2007 | 10:39 AM
KNONFS's Avatar
B O R I C U A
I was waaaay off
Old Dec 13, 2007 | 10:41 AM
crispeed's Avatar
'Tuna'
BINGO!!!!!!!!
There use to be pics of beno vs the samurai warrior on some site.
I remember when 'beno' use to take the rx-3 out to lakeland dragstrip way back in the 90's. It was around the same time 'ping', 'loquito' junior built the r-100. I also remember the rivalry between him and 'Edwin' 'Loquito Killer'. Those were the good old days.
Old Dec 13, 2007 | 10:46 AM
crispeed's Avatar
'Tuna'
Ito.
Do you know who 'Cripspeed' was?
Can't remember if it was spelt with a K or C.
Old Dec 13, 2007 | 12:05 PM
fbdrifterrx7's Avatar
El loquito papa
Old Dec 13, 2007 | 07:05 PM
RoTaRyBoYz's Avatar
InsaneRotaries.com
history
I've bookmarked this site almost 10years ago and im supprise its still alive.. http://www.go.to/puertorico
Old Dec 13, 2007 | 07:29 PM
13B-RX3's Avatar
7s before paint!!!
"The King of the Rotor World"
Rafaelito (13B Turbo, NOS & WEBBER)7.72 @ 173mph
A wee bit outdated . I remember this site though. I ran across it looking for info about papote's RX-3. He IS the reason i built my rx. After seeing his car i was hooked!!!!!
Old Dec 14, 2007 | 09:25 AM
rotaryB-2000's Avatar
Psalms 37**25
Originally Posted by Viking War Hammer
This car (Racing beat) is still alive..in Mayagues PR...and the black RX3 that says Loquito is also alive in PR..they should be in a museum..
Old Dec 17, 2007 | 08:55 AM
Judge Ito's Avatar
Ito.
not sure cris, from where??
Old Dec 17, 2007 | 06:36 PM
h_turbo's Avatar
Amazing, I never thought this was the reason why there are no rotaries in NHRA.
Old Dec 17, 2007 | 06:57 PM
mono4lamar's Avatar
In the burnout box...
Wack son...
Old Dec 17, 2007 | 10:53 PM
mannyvidal's Avatar
come get some.....
Ito.
that was the guy who started KFC , right
