Need instructuctions for Blitz SUS intake
Old Apr 15, 2002 | 12:35 PM
From: Minnesota, now in FL and I dont think I'm goin back
Like above I need some instructions, but I think I could do it without them. It would be nice though if someone had some
Old Apr 15, 2002 | 02:20 PM
GoRacer's Avatar
Speed Mach Go Go Go
They are in Japanese
The only really hard part is the stupid metal clamps. Replace them with screw down or twist down ones.
It looks worse than it is because of all the hoses, just time consuming. The two holes on left don't need a "L" bracket. The filters do but I only screwed in the left filter because the right one screwed in is too high for the hood rod. If you have a SMIC then the right rear hole will line up. Don't know what the Right middle hole is for.
Old Apr 15, 2002 | 05:36 PM
I am having a hard time lining up the holes to screw down the filters. All of those black little L brackets suck. Do you have to screw down both filters?
Old Apr 15, 2002 | 07:27 PM
GoRacer's Avatar
Speed Mach Go Go Go
It's supposed to work with SMIC
I have a Greddy SMIC, so the heat sheild doesn't line up on two of the holes.
Looking strait at the front of the car: You may have to rotate the bracket "under" the heat sheild to line up the holes and may even have to bend the rear left a bit to start screwing it in.
Since I don't have the R-Front bracket (removed for Greddy)under the heat sheild, that's not screwed in. I only have the left filter srewed down to the heat shield. If I screw down the right filter with the "L" bracket, it sticks up to high for the hood rod.
Old Apr 15, 2002 | 07:45 PM
Do I have to screw in both filters? And whats with that big black piece?
Old Apr 16, 2002 | 09:54 AM
