Corvette rims
Old Dec 9, 2007 | 08:11 PM
SleepeR1st's Avatar
Corvette rims
Are there rims like this, http://i51.photobucket.com/albums/f3...ckonblack2.jpg
For an FC? Those are ******* sexy
Old Dec 9, 2007 | 08:36 PM
Black91n/a's Avatar
Corvettes are GM's and GM uses a 5x4.75" bolt pattern, we use a 5x4.5" bolt pattern, they won't fit. Besides, they're probably far too wide with too high an offset to fit anyway.
Old Dec 9, 2007 | 08:52 PM
CarzArKoo1's Avatar
I think this look similar, http://www.rallysportdirect.com/shop...el-p-2241.html is call Advan Model 5
Old Dec 10, 2007 | 09:48 AM
owen is fat's Avatar
oh hells yeah Advan Model 5 in 18x9/18x10 do it uP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 10, 2007 | 08:42 PM
SleepeR1st's Avatar
Not sure if im ready to throw down 2 grand on some rims, even though they are sexy :P
Old Dec 10, 2007 | 09:10 PM
rosey's Avatar
I thought about doing it(fc), you would need a pretty tricky wheel adapter/spacer setup, probably custom built.
http://tomzwheels.com/catalog/produc...roducts_id/101
I was going to use these, the front spacer would have to go from 5x4.5 to 5x4.75 and be 40+mm thick(effectively making a 17x9.5 wheel with a 10-15mm offset), with some wide fenders. Rears would have to have the same adapter, but only about 30-35mm thick. I decided to scrap that idea because getting the spacer made would have been almost as expensive as the wheels themselves, and using spacers/adapters that thick made me kinda uncomfortable. It would probably work better with an FD seeing as the spacers wouldn't have to be as thick and you could get away with stock fenders.
PS...I like how a whole set of z06 motorsport wheels are cheaper than one single Advan Model 5, lol
Old Dec 11, 2007 | 12:03 AM
CarzArKoo1's Avatar
offset 54 is hard to fit
Old Dec 11, 2007 | 12:54 AM
dumbkid's Avatar
replica wheels have an offset that will work, but the bolt pattern is still different.
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
