manual transmission identification
Old Dec 6, 2007 | 10:48 AM
mazdaverx713b's Avatar
Have RX-7, will restore
just wondering if you can identify the year of the trans(5spd) on an FB based on the serial number on the bellhousing or are there any identifiable marks on the case that would distinguish a change throughout the model years or help to identify the model year of the trans?
Old Dec 6, 2007 | 10:52 AM
gsl-se addict's Avatar
Super Moderator
vent on bellhousing = GSL-SE
remote shifter = 81-85
non-remote shifter = 79-80
Not sure on the numbers and such. You can also narrow the year down by the number of sensors (reverse, neutral, 5th gear).
Old Dec 6, 2007 | 10:58 AM
i know what the SA trans looks like. i have 4 FB 5speeds and i'm getting ready to do a manual trans swapinto an auto FB and i want to see if i have an 84 or 85 trans. what is the count on the switches on the trans based on model year?
Old Dec 6, 2007 | 10:59 AM
mar3's Avatar
Administrator
The 79-80 shifter housing detail...
The 81-85 shifter housing detail...
If you've got an FB transmission, the year is irrelevant..if it's a 1stgen, it will fit.
Attached Thumbnails manual transmission identification-sa-shifter-housing-top-shot.jpg   manual transmission identification-fb-shifter-housing-top-shot.jpg
Old Dec 6, 2007 | 11:01 AM
thank you for the pics mar3! i am aware of the SA trans's identification marks and know the differnce between an SA and FB trans but those pics will be a great refernce for anyone who doesnt know the difference!
Old Dec 6, 2007 | 11:04 AM
Glazedham42's Avatar
Resurrecting Gus
Good luck with the 5 speed conversion Dave. I did it once, and it is absolutely without a doubt, worth all of the work it takes. I never regretted it for a second afterwards. And as far as swapping those pedals in, may the force be with you....
Jamie
Old Dec 6, 2007 | 11:35 AM
Rx-7Doctor's Avatar
Actually all 84-85 transmission have the vent on bell housing.
I don't remember if the 84-85 12a transmissions have the 5th gear switch on them or not. I'll have to look at the parts catalog.
Old Dec 6, 2007 | 12:05 PM
when you do, please let me know. i guess i'm just trying to get the gear ratios with the trans and diff matched up so that the spedometer will be accurate.
Old Dec 6, 2007 | 12:10 PM
Rx-7Doctor's Avatar
Most of the speedometer drive gears are the same. Pull the one from the trans that you are replacing and the one that you would be installing and count the teeth on them.
Old Dec 6, 2007 | 12:56 PM
good idea doc!! i am going to probably wait until spring to start the swap but i am going to gather all of the info i need to do the conversion early so that i can prepare myself.
Old Dec 7, 2007 | 12:15 AM
does anyone know if the serial number on the trans does in fact link it to a specific vin? i would imagine that it would....
Old Dec 7, 2007 | 09:26 PM
trochoid's Avatar
Old Fart Young at Heart
Afaik, they never tied engine, trannys and vins together on paper, except maybe on thier own inhouse build sheet.
Old Dec 7, 2007 | 09:58 PM
ok. i know that the engines and transmissions do have serial numbers and now, even more so i wonder why. i nknow more modern cars have the engine and trans numbes linked to the vin. my 92 Camry SE does and those numbers were verified by the state of ohio's ridiculous inspection when i got the salvage title converted to a rebuilt title. i guess i'll just end up counting the teeth on the speedometer gear in each of the transmissions that i have and compare those to the teeth on the speedomeer drive gear in the automatic trans thats currently in the car.
Old Dec 9, 2007 | 06:51 PM
i'll take a pic of the trans i am wanting to use and post it up. maybe it has a feature that someone will recognize. i can also compare the picture to the other 3 5 speeds that i have
Old Dec 9, 2007 | 09:05 PM
IanS's Avatar
Ricer
All I know about trans is the trans mount is different and needs swapped over when going from 81-82 cars and 83-85 cars. The mount depends on the car year and either mount will bolt up to any 81-85 trans (as far as 5 speeds go). I hope that makes sense somewhat...
Old Dec 9, 2007 | 09:30 PM
j9fd3s's Avatar
Community Builder
if you run the vin number, and the info's in the computer it will come up with an engine number.
however everything before 91 wasnt on computer originally, so if there is a master list, its in a filing cabinet somewhere
Old Dec 9, 2007 | 11:01 PM
trochoid's Avatar
I figured you'ld know for sure, numbers guy, lol.
Old Dec 10, 2007 | 12:04 PM
mar3's Avatar
Administrator
All I know about trans is the trans mount is different and needs swapped over when going from 81-82 cars and 83-85 cars. The mount depends on the car year and either mount will bolt up to any 81-85 trans (as far as 5 speeds go).[/QUOTE]
I'll take some side shots of the two examples I've got to illustrate this difference tonight...
Old Dec 10, 2007 | 02:19 PM
ok that will be cool.
Old Dec 11, 2007 | 01:42 PM
Mark S's Avatar
There's a page like this for the 7 as well... Let me see ifI can find it...
http://members.aol.com/solomiata/Drivetrain.html
Speedo gear chart
Car Tooth count gear color notes
84-85 12A RX-7 17 green '79-83 coarse gears
84+ B2000/2200 truck,
84-85 13B GSL-SE RX-7 18 purple
86-91 RX-7 convt 19 red (small diameter)
90-91 Miata, 86-91 RX-7 20 black
1989-90 RX-7 GTUS 21 white 4.30:1 rear ratio
1979-82 RWD 626 22 Red
92+ Miata 23 Red
Old Dec 13, 2007 | 07:48 PM
mar3's Avatar
Administrator
The pics....
Attached Thumbnails manual transmission identification-sa-vs-fb-transmission-lengths-1.jpg   manual transmission identification-sa-vs-fb-transmission-lengths-2.jpg   manual transmission identification-sa-vs-fb-transmission-lengths-3.jpg
Old Dec 13, 2007 | 08:15 PM
Skidtron's Avatar
Being poor sucks!
They do not only the SE does
Enzo1944
Sep 6, 2015 08:57 AM
