Pics From ECU Grounding
Old Apr 14, 2002 | 06:17 PM
Smoke's Avatar
Thumbs up Pics From ECU Grounding
Well I thought that I might put some pics up for grounding the ECU. They are not the best pics but can give the basic idea for those thinking of doing it. Here ya go
The Original Crimp
My 12 Gauge Wire Soldered Up
Where I Put the New Ground Wire
The Complete Setup
So there it is sorry about the image quality.
Old Apr 14, 2002 | 06:28 PM
BiG WaNkLeR's Avatar
Nice, did it fix your hesitation?
It's really pissing me off, I'm going to try it in a few days
Old Apr 14, 2002 | 06:31 PM
That reminds me. I have both ecu's. I don't think I changed my ecu when I changed the engine. Not sure what ecu is there now or if they are different. The original was an 87 and I put an 88 engine in. What's the difference between the N327 and N326?
Old Apr 14, 2002 | 06:35 PM
Smoke's Avatar
Yes it did take care of my hesitation and my A/F guage no longer bounced. That is supposed to be a grounding issue as well. As far as the 326 vs. the 327 I don't think that there is a difference that you need to worry about. The important stuff should be the same unless you have the high ohm injectors from '88. There might be a difference there, someone correct me if I am wrong on that.
Old Apr 14, 2002 | 06:41 PM
Sweet, describe a little of how did the car feel after. Did you really feel a jump in power than our regular loss?
Thanks
I never changed injectors when I changed engines. I changed it from one car to the other in a day, nothing to elaborate
Old Apr 14, 2002 | 06:44 PM
Smoke's Avatar
Well on the first drive you can just feel how smooth the rpm band should be. I had a pretty bad hesitation, I don't know how bad yours is but you should be able to tell a difference. If I can remember correctly the response was a little more crisp as well.
Old Apr 14, 2002 | 06:54 PM
That's awesome.....can't wait
Got a different question while your on. Does your email notification work or did they disable that?
Old Apr 14, 2002 | 07:02 PM
Smoke's Avatar
I have not gotten any emails today for my posts they may have taken it away for now.
Old Apr 14, 2002 | 07:33 PM
Ni5mo180SX's Avatar
White Comet
Thanks for the pictures
Old Apr 14, 2002 | 08:32 PM
86Rx7GXL's Avatar
witch wires did you ground?
Old Apr 15, 2002 | 08:27 AM
Smoke's Avatar
At that time I just did the ground on the injector gang plug. I will do the others some day, I will post pics when I do so. I will most likely do it soon to see if it helps my TPS problem.
Old Apr 15, 2002 | 03:23 PM
86Rx7GXL's Avatar
witch wire is that? the gound for the injectors? also witch onther ones were you gonna ground?
Old Apr 15, 2002 | 06:25 PM
Ni5mo180SX's Avatar
White Comet
so umm...........how do I access the ECU? I looked into the opening by the footwell but what do I do next?
Old Apr 15, 2002 | 06:39 PM
NZConvertible's Avatar
I'm a boost creep...
Here's the how-to on regrounding the ECU .
Old Apr 15, 2002 | 09:17 PM
86Rx7GXL's Avatar
thanks man
Old Apr 15, 2002 | 09:34 PM
Smoke's Avatar
NZ didn't you just get a cookie for that!
Old Apr 15, 2002 | 10:12 PM
allstyle's Avatar
ECU
I'm on it tomorrow.
Old Apr 16, 2002 | 09:11 AM
You got all those mods and you still have the hesitation?
That sucks
Old Apr 16, 2002 | 09:44 AM
Smoke's Avatar
I agree with BiG WaNkLeR
Old Dec 1, 2003 | 08:11 AM
<SMOKE> Could you repost those pics again? I am unable to view the pics.
Queppa
Nov 18, 2024 03:47 AM
streetlegal?
Mar 17, 2022 02:46 PM
Daua118
SE RX-7 Forum
Dec 5, 2021 04:15 PM
Skeese
65
Mar 28, 2017 03:30 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
