13b turbo sparkplugs on a gsl-se?
Old Dec 2, 2007 | 02:23 PM
maikelc's Avatar
Rx7
I was told you could use ,2nd gen turbo sparkplugs on a regular gsl-se engine to inprove performance,is this thrue?and what are simple things i could do to make the car a little faster?
Thanks
Old Dec 2, 2007 | 02:32 PM
Druken's Avatar
Nekurd
I think all 1st gen's and 2nd gen's use the same ngk spark plugs. When I checked at Kragen, they list the same plugs, even for the turbo.
Old Dec 2, 2007 | 02:58 PM
85 FB's Avatar
7-less
Most simplest thing you can do to make it quicker would be to run Royal Purple oil through the entire car: engine, tranny, diff.
Open air/forced air intake.
Lightweight flywheel.
Not-so-simple things:
A turbo.
Change out your diff or diff gears to allow a slightly higher top speed, but you'll end up losing acceleration numbers, IIRC.
Old Dec 2, 2007 | 03:30 PM
maikelc's Avatar
Rx7
thanks guys!
Old Dec 2, 2007 | 05:28 PM
trochoid's Avatar
Old Fart Young at Heart
Not even close, plug type/style betwen the 2 is totally different.
Old Dec 2, 2007 | 06:00 PM
maikelc's Avatar
Rx7
So it wouldn't wrk?
thanks
Old Dec 2, 2007 | 07:01 PM
moremazda's Avatar
Gone Race'n
No they do work. Although if you are running a car N/A I don't know that you would see any quantitative difference between the two.
Old Dec 2, 2007 | 07:07 PM
K-Tune's Avatar
FD Daily
sure it will work fine, will there be a difference in performance? not likely.
edit also:
all FC run the same plug, turbo or not.
Old Dec 2, 2007 | 07:09 PM
trochoid's Avatar
I've run 2nd gen NA leading plugs in the wb, didn't notice any difference between those or the stock ones.
Old Dec 2, 2007 | 09:07 PM
mjm4jc's Avatar
84 SE
The only time that it is necessary to use 2gen plugs in a first gen is if you converted to the 2gen DFIS. Even then, it is a debatable subject, and it is only the leading plugs that are changed, not the trailing. Otherwise, the first gen plugs are as good as it gets.
Mike
Old Dec 2, 2007 | 09:22 PM
yetterben's Avatar
7less for now!
I have a set of spare fc plugs in the glove box just incase. They seem to flood out easy on my car anyway. Maybe becasue the fb stock ign system cant give it a good spark??? But they do work
Old Dec 2, 2007 | 10:15 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
the 9 heat range plugs are colder than the 8's speced for 1st gen. and they therefore don't burn off carbon deposits on the PLUGS as well as the 8's. Therefore the 9 plugs get 'blacker'.
i recently switched from the 9s *T2 and 3rd gen plugs) to 8s (bur8eq14)
tailpipe is not as black.
less fuel smell in exhaust.
engine starts better and accelerates better. yes, really.
u don't need a 9 heatrange plug in a n/a daily driver IMHO.
You can also get the ngk iridium plugs in 7 heat range, peoples really like them. i have a new set ready to install soon.
Best of luck.
Old Dec 2, 2007 | 11:02 PM
bugman1973's Avatar
advanced novice
i run two different sets in my rx7 and it runs better ill get the numbers for you hold on.........................................
back. for the trailing i use br9eq-14 stock #3129 and the leading i use bur7eq stock #3559. they work pretty good for me. never any issues i even use them on a stock 12a
Old Dec 3, 2007 | 08:03 AM
maikelc's Avatar
Rx7
thanks to everybody for their time!
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
