Garrett Gt40r Turbo
Old Nov 29, 2007 | 09:25 PM
elmoose's Avatar
Garrett Gt40r Turbo
hey Guys i just bought a 93fd with Some mods...(See below).what hp am i look at? the motor was just done by Mazda 6500 miles ago the motor has no porting.i have to get IT tuned(www.rx7s.com) next week.Also its running stock fuel lines and injectors.Any recommendations on does...........I'm look for street driving and sometimes at the track.I dont know to much about rx7"S im a ex srt4 guy sorry
AGENCY POWER BOOST CONTROLER
GREDDY CATBACK EXHAUST
APEXI DOWN PIPE
BONEZ MID PIPE
APEXI POWER FC (ECU)
FC DATA LOGIT
CUSTOM MANIFOLD
FRONT MOUNT INTERCOOLER
TIAL BLOW OFF VALVE
GREDDY ELBOW
GREDDY PULLY KIT
GARRETT GT40R TURBO (DUAL BALLBEARING)
GREDDY OIL CATCH CAN
TURBO TIMER
POWER FC COMANDER
Old Nov 29, 2007 | 10:11 PM
td06Se3p's Avatar
Looks good. I'd say 300+ with ease but at what boost level (thats why I said a really reasonable #). Get the tune first to make sure shes running the way she should (you want as well) like you said. I would up grade the fuel system and clutch (didnt see it on there and for ones own sence of mind) so she wont give way during those track runs. Porting couldnt hurt but since shes still fresh I'd do all the above but then again I'm alittle power hungry. I'm sure somebody else will chime in that has a better idea than me. My .02
Old Nov 30, 2007 | 08:12 AM
elmoose's Avatar
Thanks. what kind of clutch should i get? again i wonna use in on the street
Old Nov 30, 2007 | 01:48 PM
classicauto's Avatar
Crash Auto?Fix Auto.
ACT extreme with the street disc is a great street/strip clutch.
Old Nov 30, 2007 | 02:56 PM
pwwatkins's Avatar
Supra Smasher
First get a fuel pump and some injectors. Next get clutch and tune. You should be a tiny bit over 400 on pump gas. You may need to add an ignition amp too.
Suggestions on parts: Supra fuel pump, 850 and 1680 injectors, ACT extreme clutch. HKS twin power
Old Nov 30, 2007 | 03:39 PM
elmoose's Avatar
Im looking thru the recites and foud it also has a Exedy Clutch stage 2 already with 6400 miles on it.Was installed with the new motor.So all i need is fuel,tunning and injectors. thank you
Old Dec 1, 2007 | 09:44 PM
diabolical1's Avatar
if you don't already have the turbo, then i suggest sizing it better unless you plan to port the engine to support that turbo. a GT40R is a great unit, but stock ports are not going to do it justice and you will more than likely end up unhappy.
Old Dec 2, 2007 | 11:05 AM
cliprun's Avatar
GT40 is a really good turbo to make alot of power.. Just have to have the motor to support it
Old Dec 2, 2007 | 02:52 PM
mr2foryou's Avatar
600+rwhp club member
Yes, it's plenty of turbo. Just get all your supporting mods and get a compression check before you start really boosting it hard.
Dee E.
Old Dec 4, 2007 | 02:24 PM
elmoose's Avatar
The turbo is already installed.on the new motor could i just get it tuned withcthe stock motor and updraded fuel and injectors.you guys think I could put down 320hp...also would this hurtbthe motor because is not ported
Old Dec 4, 2007 | 08:22 PM
pwwatkins's Avatar
Supra Smasher
It doesn't hurt the motor at all. The stock ports are just to restrictive to get quick spool and high hp. Don't forget to upgrade the fuel pump too. You should be able to get 400hp on pump, maybe a little more with some good tuning.
Old Dec 5, 2007 | 08:31 AM
elmoose's Avatar
OK sounds good i will post the result in a fews Weeks when i get it tuned
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
R7rexy
19
Sep 2, 2015 10:24 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
