atmosphere pressure sensor? please help
Old Apr 13, 2002 | 06:59 PM
hey guys i need ur help. i tried to check my atmosphere pressure sensor. that is the one that goes to that little black box right?? well i pulled the plug out and tested it. it is like 4.9 volts. i tested it with a ground and the red wire to the d clip in the plug. what i need to know is did i adjust the wrong thing? it has that screw right beside it u turn. well now it smells nasty. runnin rich, and its slower and not holdin same idle as before. how can i get this thing back to normal? like how do i use the voltmeter right so i dont screw anything else up. thanks
Old Apr 13, 2002 | 07:05 PM
HAILERS's Avatar
HAILERS
Atmospheric pressure sensor is inside the car, passengers side, up and to the right. What you describe might be the variable resistor in the engine bay, forward of the right front strut tower, oval in shape and black.
Old Apr 13, 2002 | 07:07 PM
yea yea thats it dangit what did i do?
how do i adjust that
Old Apr 13, 2002 | 07:34 PM
HAILERS's Avatar
HAILERS
Two jpgs to follow, the second one shows the variable resistor.
Old Apr 13, 2002 | 07:36 PM
HAILERS's Avatar
HAILERS
Variable two:
Old Apr 13, 2002 | 08:26 PM
yea the second one was the one that i had adjusted. well i dont have a jumper wire. where can i get one. or how do u make one. i adjusted it without a jumper wire in so what does that do??
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
t-von
Sep 10, 2015 01:56 PM
vmerino
Sep 5, 2015 11:26 AM
