what fuel setup should i run?
Old Nov 28, 2007 | 02:18 AM
matt g's Avatar
I have a HKS t51r kai full turbo kit and i want to run 15psi to 18psi. I was thinking of getting the rx7store fuel kit but i don't want to replace the primary fuel rail and there kit comes with it. Do i need to replace the primary injectors or can i keep them stock? I just wanna know what is the best setup would be without spending a lot of money.
thanks
Old Nov 28, 2007 | 03:16 AM
pwwatkins's Avatar
Supra Smasher
Most people including myself use the stock 850 sec injectors in the primary spot with a little modification, while you have them out you should also get them cleaned and flowtested.
Old Nov 28, 2007 | 03:40 AM
matt g's Avatar
I have about 5000 miles sence they where cleaned and flowtested by rc. What modification do i have to do for them to work? What brand 1600 injectors are you running also are you running the stock rail?
thanks for the help.
Old Nov 28, 2007 | 10:31 AM
Jason's Avatar
The one
Matt
The extreme kit we sell only comes with the secondary rail. Its the ultimate system that comes with the primary.
Link here:
http://www.rx7store.net/product_p/extremefuelfd.htm
Like pwwatkins said, just move the 850's to the primary spot. You will need to mill down the primary rail for that.
Jason
Old Nov 28, 2007 | 08:46 PM
matt g's Avatar
Hi jason do you have a stock primary rail that is milled in stock? and ill send mine to you for a core.
thanks
Originally Posted by Jason
Matt
Link here:
Jason
rotor_veux
46
Jun 12, 2018 10:39 AM
dkwasherexd
May 27, 2017 04:51 AM
Wolf_
Aug 11, 2015 04:23 PM
