omp
Old Nov 27, 2007 | 01:25 PM
danhaggis's Avatar
A fellow rotary guy
Veteran: Marine Corp
omp
ok i put a s4 waterpump assembly on my s5 and the omp solinoid now hits the housing and when i diconnect the omp the car went into limp mode anyone have any ideas???
Old Nov 27, 2007 | 01:35 PM
alexdimen's Avatar
TANSTAFL
Put the right parts on your car...
Old Nov 27, 2007 | 01:46 PM
Aaron Cake's Avatar
Engine, Not Motor
If you remove the S5 metering oil pump, the car goes into limp mode. Nothing you can do about it but put the pump back on or convert to a full standalone.
Old Nov 27, 2007 | 02:19 PM
danhaggis's Avatar
A fellow rotary guy
i was running away from spendint the money on the new thermostat housing, my plastic one crumbuled and i need the car to go to school, plus i dont have the 120 for the new aluminum one any suggestions?
Old Nov 27, 2007 | 02:53 PM
sunshine's Avatar
1) either get the correct wp housing, or
2) swap front covers and t/b to get the mechanical omp - but them u will need to keep the s5 omp plugged into the harness so the ecu still sees it.
3) or plug in the omp, let it dangle so the ecu sees it, and block the omp port on the cover, and go full premix.
only 3 options
-a
Andrew7dg
Aug 6, 2017 01:41 PM
lnlreaper
Sep 27, 2015 09:59 AM
