Rotors all rusted solid, Need to pull the car into the garage but she wont budge!
Old Nov 26, 2007 | 03:00 PM
rx7 punk's Avatar
I really dont feel like tearing apart the brakes just yet because I have a broken wrist at the moment. I have been hitting the rotors daily for about a week with Penetrating oil and today tried to pull the FC with my truck. I did break loose one of the front wheels but the others are solid.
My truck pulled the FC for like 20 feet, I could have pulled her all day like that.
Ideas guys?
Old Nov 26, 2007 | 03:22 PM
Killert2's Avatar
try throwing some dw-40 or those things that breaks rusted bolts loose on there and let it soak over night maybe that do something
Old Nov 26, 2007 | 03:44 PM
MaczPayne's Avatar
Mac Attack
Damn those are some stuck brakes! Throw some PB blaster on it and let it sit for a bit.
Old Nov 26, 2007 | 03:59 PM
Aaron Cake's Avatar
Engine, Not Motor
WD-40 does nothing.
PB Blaster is the ideal penetrating oil.
Try smacking the rotor with a hammer. Any play in the bearings will cause the rotor to lean slightly, which will break them free from the pads. This has always worked for me.
Old Nov 26, 2007 | 04:10 PM
rx7 punk's Avatar
^Thank you sir!
I had been trying that ZEP **** and it didn't do anything. Im thinking about a 5 lug swap but cant find a write up anywhere
I though felixwankel did one but cant find it.
Old Nov 26, 2007 | 04:37 PM
20Bforme's Avatar
three spinning triangles
its super easy... you wont need a write up...
Old Nov 26, 2007 | 04:52 PM
rx7 punk's Avatar
^LOL what do I need to pull from the donor car in the junkyard? Everything thats attached to the lugs?
Old Nov 26, 2007 | 05:19 PM
20Bforme's Avatar
pretty much...
front hubs: remove caliper, remove brake disc, remove hub dust cap: remove cotter pin, remove nut > front hub comes off car
rear hubs: remove brake parts, un-stake hub nut and remove (youll need a breaker bar and something to keep the hub from spinning), remove upper, lower, and DDTS bolts... next youll need a 2 prong gear puller to push the splined axle out of the hub (thats what i needed to do anyways)
the rear was the most difficult part... i ended up ruining the ddts bushings cause the bolts were seized to the sleeve... used a torch to fry the rubber out... then the bolts came out nicely...
Old Nov 26, 2007 | 05:53 PM
farberio's Avatar
NASA-MW ST4
https://www.rx7club.com/showthread.p...ighlight=5+lug
and
http://howto.globalvicinity.com/gv_w...i=51&co=1&vi=1
dkwasherexd
May 27, 2017 04:51 AM
cam_7779
Aug 18, 2015 07:48 AM
