How To clean Injectors...
Old Apr 13, 2002 | 12:44 PM
87GXLRX7's Avatar
If some one could tell me how to clean up my old injectors i would appreciate it... i have them off i just don't know how i should clean them... thanks for the help.
Old Apr 13, 2002 | 03:01 PM
Bambam7's Avatar
I came, I saw, I boosted.
Well.. professional unltrasonic cleaning is the best way to go- unless you have access to an ultrasonic parts cleaner, or can convince a jewelry store to let you use theirs!!!
RC does it.
You can do some yourslef though, and clean them up a bit.
Get a can or carb cleaner or something comparable, and a DC transormer from radioshack or something with a 1-2 V output (1-2, not 12!!!)
If you try and open the injector with 12V- it'll fry in less than 10 seconds. Not good. It'll open with as little as 1V.. and can stay open for a LOT longer safely
Attach the wires to the injector, (real lucky if you have a spare plug too!)and you'll hear it click- it just opened.
I find that if you blow the cleaner backwards through the end of the injector (with the red straw that comes with spray cans), whith the injector open, it works well.
Spray it both ways, but try not to leave the injector on for more than 30 seconds... I like to flick it on and off while spraying, to clean up the moving elements inside.
Once thats done, soak the tips of the injectors in degreaser or carb cleaner overnight. (with the injectors off of course... or, if you are really serious, rig up a standard flasher relay or something to the circuit to keep the injectors opening and closing!!)
Once thats done, the next day, give it another clean spraying with the injectors open, and that's about all you can do.
Old Apr 13, 2002 | 03:28 PM
87GXLRX7's Avatar
thanks alot
Old Apr 13, 2002 | 03:36 PM
87GXLRX7's Avatar
i am using a AA battery as my power source
Old Apr 13, 2002 | 03:40 PM
bingoboy's Avatar
Lava Surfer
oh sweet, you can use a little baby battery. i was just about to ask that. its all working ok with the AA?
Old Apr 13, 2002 | 03:50 PM
87GXLRX7's Avatar
yep working good ... its clicking just fine
Old Apr 13, 2002 | 03:57 PM
Aaron Cake's Avatar
Engine, Not Motor
Uh huh....
OK, there is no such thing as a DC transformer. So you obviously can't use one of those to clean your injectors.
Best advice is to get them professionally done. Most diesel shops do it for between $10 and $35 per injector.
Old Apr 13, 2002 | 04:09 PM
87GXLRX7's Avatar
i duno about no transformer... all i know is if ur cheap like me.. you can just use a AA battery to open then the injectors...
Old Apr 15, 2002 | 08:48 AM
jimmyv13's Avatar
Round&Round not Up&Down
I sent mine to Marren Motor Sports out of Connecticut. Balanced and blueprinted with new orings, caps, and inline filters for $23.75/ea.
Here's the link Marren
Old Apr 15, 2002 | 05:58 PM
So what if.....
My question is this.. if you have leaky or old injectors, at what point to do you replace them as opposed to sending them off for either cleaning or rebuilding? And if you put larger injectors on a motor, does the computer know that its getting more fuel ?
Old Apr 15, 2002 | 06:31 PM
NZConvertible's Avatar
I'm a boost creep...
Re: So what if.....
It's uncommon to have to replace them. They can usuually be brought back to near-new condition by a professional cleaning. If they're truely shagged, they'll tell you.
Nope! You need a piggy-back fuel computer or anaftermarket programmable ECU.
squirrels
Sep 24, 2015 03:33 PM
younG_Gunner
Sep 9, 2015 08:26 PM
