Car hesitates before fully warmed....normal?
Old Nov 25, 2007 | 10:07 PM
RXecutioner7's Avatar
hey guys i have a 90 TII and my car hesitates like it's starving for fuel until it is fully warmed up and then it is fine....my air/fuel gauge is almost in the rich when it is shuttering. is it a sensor? all emissions removed, i don't know anything about thermowax so could it be this?
Old Nov 25, 2007 | 10:18 PM
alexdimen's Avatar
TANSTAFL
When does it hesitate? RPM? Throttle position?
Old Nov 25, 2007 | 10:34 PM
about half throttle it starts.....once it is warmed, it runs like a champ.
Old Nov 25, 2007 | 10:38 PM
texFCturboII's Avatar
version 2.0
water thermosensor connector.... that's what solved my cold shuttering problem.
Old Nov 25, 2007 | 10:44 PM
did you replace the sensor or just the connector...thanks
Old Nov 25, 2007 | 10:51 PM
version 2.0
I replaced both.... the sensor first, then I discovered it was the connector that was bad. lol.
Old Nov 25, 2007 | 10:59 PM
cool...thanks again i will do it, heck it needs it anyway
Old Nov 25, 2007 | 11:02 PM
version 2.0
BTW, you should be throwing a CEL on start up if its out though... are you throwing any codes?
Old Nov 25, 2007 | 11:05 PM
my check engine light never came on but i know the light works bc when my o2 sensor came loose it came on.
Old Nov 26, 2007 | 03:33 AM
version 2.0
then maybe the tps or afm is outta whack a little? run some tests with a multimeter, refer to the FSM for specs, available in the FAQ's. those would be my three culprits.
highspeedrider
Sep 8, 2015 07:55 PM
Feffman
Midwest RX-7 Forum
Sep 1, 2015 07:30 AM
sYnth.
Aug 17, 2015 07:28 PM
Feffman
Racing Kills Lounge
Aug 15, 2015 06:19 AM
