What's an IAS plug? Need help with rat's nest removal..2
Old Nov 23, 2007 | 07:26 PM
dirteeboy808's Avatar
No. 51 in writeup, what's an IAS plug
http://www.rotaryresurrection.com/2n...s_removal.html
I just completed rat nest removal, car starts, but I need to hold the throttle down so the car doesn't shut off any suggestions??
Old Nov 23, 2007 | 08:16 PM
RotaMan99's Avatar
Intake Air sensor maybe? Although I usually type IAT Sensor for Intake are temp sensor.
Old Nov 23, 2007 | 08:28 PM
smells like its burning oil and clouds of white smoke is coming out...seems like there's hesitation all the way till 6k....then releases...popping and backfiring too
Old Nov 24, 2007 | 06:05 AM
RotaMan99's Avatar
There are a few things you do NOT want to remove which the writeup tell you to remove.
1. Steps 15, 26, 33. Purge Control Valve. Allows moisture and bypass gases to esacpe, not the same as venting to atmosphere, vacuum is applied to the oil sump when over 2000rpm or so.
2. Step 32 BAC (Bypass Air Control Valve). This stabilizes the idle to compensate for mechanical loads on the engine. Also bumps the idle up to about 2000rpm at every start up for a few seconds.
3. Steps, 22, 23, 38, 40 Thermowax. This is what keeps the engine from stalling when cold. This is why you need to hold the gas till the engine is warm. Removing this makes no sense at all.
How cold is it near you? White smoke could be just clouds of moisture. Poping and backfiring may be a bad connection at the TPS. you may need to readjust the TPS after fiddling with everything too. Even though you don't think you would have too.
Make sure your AUX ports are working correctly. Push the actuator rod down into the actuator to make sure they move freely. Then check to make sure the small metal tube sticking out on the left side of the rear actuator is connected to the pipe coming from the CAT if you have one.
I hope you don't have a CAT since you removed the airpump and ACV right?
Old Nov 24, 2007 | 06:15 AM
mechanical loads?
I live in Hawaii so cold really isn't too much of a factor, I'll try adjust the TPS and seee what that does
I checked them out the move freely
No cat =)
arghh, I should have just left it alone, the car was working fine prior to removing all this crap
Old Nov 24, 2007 | 06:25 AM
RotaMan99's Avatar
It happends
So im guessing the AUX ports are not hooked up to anything?
If you are sticking with no cat, and the ports are not hooked up to anything, then I would get a header with the aux port tube so you can activate them still.
There are electronic ways of opening the aux ports as well. Just do a lil search for electronic aux ports or electric aux ports or something of the sort.
mechanical loads?
Such as, A/C, Power steering or electrical loads on the alternator which gets directly converted to mechanical load. At every startup the BACV also bumps the idle up to about 2000rpm +/- at ever startup. This could reduce flooding.
Old Nov 24, 2007 | 06:37 AM
aux ports work fine they move when throttling
when removing the solenoid plugs, I have an extra plug that I can't seem to find out where it goes to, it looks like an injector plug, but it's together with the loom of the solenoids
do you have any suggestions or solutions as the why the power seems so flat until 5.5k, seems like it's taking long for the throttle to kick in...almost like a turbo lag to boost........lol, but it's only an NA
also post 50 of the emmissions removal it says to replace vacuum hose, but I can't for the life of me figure out where the heckit came from
Old Nov 24, 2007 | 07:57 AM
RotaMan99's Avatar
Step 50 - connect OMP rod and vacuum hose to manifold.
The vacuum hose in question is coming from the vacuum spider (5 port manifold) that has 4 vacuum lines going to the oil injectors. That large vacuum line connects to the front of the DC. Picture of the nipple to connect it to is pictured below.
Image from Rotary Resurection website
Is the plug green? If so its for the water thermo sensor located on the back of the water pump housing. Picture below.
I would have to look in the FSM (Factory Service Manual located here) to remind my self what the ECU defaults to if the WTS is unplugged or bad but this may be the cause of the power lose IF this is disconnected.
Old Nov 24, 2007 | 01:24 PM
the mysterious plug:
can't figure out where this goes
the loom of solenoids if joined with:
TB mod:
so if I removed the OMP just cap the top vacuum hole?
***** & giggles:
I also checked the link it's down......
Old Nov 24, 2007 | 04:01 PM
RotaMan99's Avatar
If the OMP is working. Just do the maintenance on it and leave it be. Premixing is a PITA and is not needed. You will have ZERO benefits from premixing.
That plug is for the BACV which you should put back on. No performance gain removing the BACV.
Old Nov 25, 2007 | 07:47 AM
RotaMan99's Avatar
I saw your other thread about the white smoke.
Do you still have your OMP on? Did you happen to cap the oil injectors air supply?
If so, this could cause excessive suction on the OMP system which could cause an abnormal amount of oil to be sucked into the engine.
Just a guess. Even though I don't think this could cause a smoking situation, just something to throw in there.
Old Nov 26, 2007 | 12:04 PM
BAC and OMP have been removed.......pre-mixing is OK with me, as for the BAC it was tossed so I don't think that will be coming back...
I'm doing a compression test as a final analysis...pretty much 90% sure that there's a seal leak somewhere
Old Nov 26, 2007 | 04:24 PM
88SE_HI's Avatar
Any chance you forgot to plug back in the afm?
Old Nov 26, 2007 | 07:06 PM
nah, I did that...I got the car to idle nicely, but the power loss in the suxxorz
I'm doing a compression test after work for the final analysis of the motor......
if the front 2 plugs are good, but the rear 2 are soaked and caked with oil..what does this mean?
Old Nov 26, 2007 | 08:54 PM
Front plug compression: 110
Rear plug compression: 140
seems healthy, but spread apart
jdayau
Nov 29, 2019 12:11 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
ZacMan
Sep 19, 2015 09:20 PM
