87 TII swap. Finally Done. Some troubleshooting though.
Old Nov 23, 2007 | 01:08 PM
cps87rx7se's Avatar
Well, after a year and a half I finally got my 87 TII swap running and took it out for a test drive. Iwont really hold an idle under 1500 rpms and I have to keep my foot in the throttle ever so slightly to keep it running (I think that this problem is from slack in the throttle cable though). The problem that I encountered when driving it on the road was that the car was fine to 3500, hicup'd and boosted all the way to 1 Bar or 14.7 psi. I backed off the throttle and the charge pipe blew off the throttle body. This tells me (from my limited experience) that the waste gate is fully closed off and not diverting exhaust away from the turbo fins at lower rpms (this could also be why it wont hold an idle at low rpms). Then when I let off the throttle after the boost, the charge pipe blew off which tells me that the blow off valve is not working properly either.
Some background on the car is that it is a 87 TII J-Spec swap into an 87 N/A. I have gone with a front mount intercooler setup, a manual boost controller, GReddy type-S blow off valve, Racing Beat FCD and removed the rats nest. The way that I routed the manual boost controller was the nipple on the compressor side of the turbo to the boost controller (opened up all the way so that it would run stock setting), then from the boost controller down to the waste gate. The blow off valve is connected on the drivers side about 8 to 10 inches away from the throttle body. The larger of the two vacuum nipples on the blow off valve was connected to one of the open vacuum nipples on the fire wall side of the throttle body right after the black plate, on the upper intake manifold.
This is creating some serious boost, but I want to get it back to stock settings before I turn up the boost and fuel. Any help or insight to my situation would be greatly appreciated. Thanks.
CHRIS
Old Nov 23, 2007 | 07:56 PM
cps87rx7se's Avatar
NE one able to help out? Please!!!
CHRIS
Old Nov 23, 2007 | 08:19 PM
scrip7's Avatar
Rotary Gearhead
Is the turbo from the s4 engine?....has the wastegate been ported? also remove the vacuum hose from the BOV and check for a fairly strong vacuum at idle. The nipples on the UIM are "timed" differently from one to the next, meaning one or another will have vacuum only above idle, such as the purge valve.
Old Nov 24, 2007 | 10:28 AM
tidanb0utch's Avatar
hi, somes things to check
- search for vacum leak
-adjust acc cable
-adjust tps
good luck whit your project
Dan
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
acha3
Sep 6, 2015 08:14 AM
