Radiator Cap Housings
Old Nov 22, 2007 | 12:10 PM
HAILERS's Avatar
HAILERS
A fellow was wanting a metal radiator cap housing and his thread got closed. Here is a site that has the metal housing: http://www.mazdatrix.com/b8.htm
Item 15-17Y0-N323 ........aluminium.
Last edited by Aaron Cake; Nov 23, 2007 at 08:48 AM. Reason: Remove reference to OT closed thread
Old Nov 22, 2007 | 12:16 PM
BrettLinton7's Avatar
Lots of rotors
that helps, as mine leaks a bit.
and hey, you can even buy the things they go over... lol
Old Nov 22, 2007 | 12:38 PM
RETed's Avatar
All that is is a stock Mazda FD unit.
Problem is that most Zenki FC's use that unit as an overlfow with a sprung cap.
-Ted
Old Nov 23, 2007 | 08:49 AM
Aaron Cake's Avatar
Engine, Not Motor
There. Fixed.
Thanks for the part info, HAILERS. I just discovered my plastic rad cap housing was leaking (that explains my slow untraceable loss of coolant...) and had no idea that an aluminum version was used on the FD.
Old Nov 23, 2007 | 10:16 AM
RETed's Avatar
Yep, been using one for YEARS!
Since mine was a bypass type, I drilled and tapped for a fitting - 1/8"NPT with a 1/4" male barb.
You need to cut down the NPT threaded side, since it needs to be shallow enough to allow the bypass, sprung cap to seat correctly (you'll understand once you stare at it enough).
This fill neck will NEVER fail like the plastic piece of **** original part!
-Ted
Old Nov 23, 2007 | 10:38 AM
Aaron Cake's Avatar
Engine, Not Motor
Since I take my coolant bottle line from the rad cap of my Fluidyne, I had long since plugged the plastic nipple by grinding it off, tapping it, then installing a grub screw. So no issues here.
Old Nov 23, 2007 | 02:13 PM
Jager's Avatar
Tear you apart
I just seen that Mazdatrix sells brackets to fit a Koyo.
I thought it was bolt in to the stock location?
Confused!
Old Nov 23, 2007 | 10:29 PM
certifiednut's Avatar
Mike Honcho
Confused!
when you install the koyo you have to use the old radiator brackets from the ends of the factory rad. they bolt on,,,
