Removing steering lock... please help!
Old Nov 21, 2007 | 05:23 PM
tigermack's Avatar
CPS Motorsport
Question Removing steering lock... please help!
I am trying to put in a better steering box for my FB... however, I am stuck at the step when it comes to the steering lock... I found this site... http://www.mazspeed.com/steeringwheellockremoval.htm but I have a question... will I still be able to use the key later on? I don't care if I have the lock or not, I just want to know if I can still use the key I been using or is it going to damage anything else?
Or...
How else can I remove it? https://www.rx7club.com/showthread.php?t=362614&highlight=remove+steering+ lock I came along with this but I couldn't fit anything into there to reach the round bolt, the work area is just way too tight and tiny.
I tried to hammer it with a flat head and it wouldn't move... I need some tips or advice on how to remove the steering lock, thank you.
Old Nov 21, 2007 | 05:32 PM
Siraniko's Avatar
RX for fun
without reading that crap, I will give you a summary.
1. Remove the steering panel.
2. Remove the vent below the dash facing the floor
3. Unbolt the steering colum from the dash 2 12mm bolts. then lean on the steering wheel to gain more space
4. Using a small chisel, tap the headless bolts counter clockwise
Old Nov 21, 2007 | 05:35 PM
tigermack's Avatar
CPS Motorsport
I guess I just have to go get a chisel and work it out slower, thanks Wacky.
I have done everything you mentioned except the last step.
Old Nov 21, 2007 | 05:42 PM
tigermack's Avatar
CPS Motorsport
Does anyone know any other way to do this??
Old Nov 21, 2007 | 06:24 PM
budrud's Avatar
Take a dremel tool and cut a slot in the head for a straight screwdriver. Then you can take it apart later if needed
Old Nov 21, 2007 | 06:45 PM
1stgenNutt's Avatar
that's the way to do it you gota lean on the colum a little to get a drimel in there but its not that hard make sure you take the cover in front of the gauges off so you dont bust it.
Old Nov 21, 2007 | 07:15 PM
Pele's Avatar
Right near Malloy
I grabbed the headless bolts with a pair of needle nosed pliers and some vice grips...
When you order new bolts, they'll have a head on top of the round head... When you tighten them down, the head will snap off. (I've not done this. This is per the FSM.)
Old Nov 21, 2007 | 07:19 PM
innertwist's Avatar
From: Huntersville, NC and occasionally back in Freeport, NY
Never tried breaking the wheel, so dunno.
For the round head bolts, I drilled a hole (using lefthand a drill bit) and used a screw extractor bit on mine. Then, I used a dremel grinding disk to cut a slot in them for future removal. When I got the first one out, I managed to get the second loose enough to not have to drill it for removal. This was on my 80, a couple of these tips sound specific to S3s such as removing the gauge cover(???). On mine the screws point downward, so I don't see why that'd be a problem. If, like budrud suggested, you can get a dremel bit up there to slot it, do it that way.
Burdrud, what dremel bit?
Old Nov 21, 2007 | 08:15 PM
budrud's Avatar
I used the grinding disk on the screw arbor, it takes a couple passes to get it wide enough but worked well. Mine went the same as innertwist, once I got one loose the other one came out easy and I could slot it on the bench.
Old Nov 22, 2007 | 12:55 AM
MtotheIKEo's Avatar
When I took mine out I just hit a flat chisel into the headless studs to put a groove in them and removed them with a flathead. Then grinded off the key that spings up into the steering column to lock it.
Old Nov 23, 2007 | 10:20 AM
K-Tune's Avatar
FD Daily
i drilled mine out. i forget its position but you can drill straight up through a part of the casting and the spring+lock come out. no they cant be reinstalled but having the lock disabled was required for a certain kind of racing.
Old Nov 23, 2007 | 11:43 AM
Pele's Avatar
Right near Malloy
Just pull the whole lock assembly and set it aside, then start the car with pushbutton and toggle switches.
Old Nov 25, 2007 | 12:35 AM
tigermack's Avatar
CPS Motorsport
I have a question though... once I have it removed... can I move it back on and work as it was never taken off before?
Do I just screw it back in with a flathead through the groove that I used the chisel with?
Old Nov 25, 2007 | 01:52 AM
trochoid's Avatar
Old Fart Young at Heart
You can, but it easier to take the screws to the hardware store and buy new ones that have a slot or phillips head.
Old Nov 25, 2007 | 02:38 AM
MTheoryInc's Avatar
rotor n00b
Top Answer: 1
Yes it will work just as it did before. The bolts are headless for theft prevention.
Get socket head screws, also known as Allen head. I think they are metric
8mm x 1.25 thread.
Old Nov 25, 2007 | 02:50 PM
tigermack's Avatar
CPS Motorsport
Thank you, guys. You guys are awesome.
I will be back IF I have any confusion.
Old Nov 25, 2007 | 07:33 PM
tigermack's Avatar
CPS Motorsport
I got those 2 bolts off! I used a chisel and just knocked it counter clockwise. Thanks for all the advices.
I am almost done with this!
risingsunroof82
Sep 7, 2015 01:11 PM
