Need Help!!! New Ownder of an RX-7!
Old Nov 20, 2007 | 10:20 PM
Juje's Avatar
Well, I was installing an Sound System in my car, after a while didn't want to install it, went to turn the car on, it wouldn't turn over. Then I found out the spark plugs were flooded, took them out, cleaned them. Now the car still doesn't start, and the car also smokes up alot when I rev the engine or just start the car. Over heating also happens...
Can anyone help me?!
I'm going nuts!
Also it's a 1986 RX-7 GXL!
Old Nov 20, 2007 | 10:22 PM
hhn2002's Avatar
welcome to our world.
Old Nov 20, 2007 | 10:34 PM
Juje's Avatar
Oh I've been it, my bro had two RX-7's two 2nd gen, 1 first gen. I always see em working on it though I don't remember on what or why. Can anyone advise me on my problem?
Old Nov 20, 2007 | 10:36 PM
Fumi's Avatar
Addicted to the PNW
replace the spark plugs with new one and search flooded s4 or something to that effect
Old Nov 20, 2007 | 10:42 PM
Juje's Avatar
Can you also help out on the part where the car over heats?
I guess I blew the Head Gasket out, well at least my friend did! Arr!!
Old Nov 21, 2007 | 01:59 AM
wiL87's Avatar
2+1=3
Old Nov 21, 2007 | 09:17 AM
Aaron Cake's Avatar
Engine, Not Motor
If the car won't turn over, make sure the battery terminals are connected properly, and are clean and tight. Also make sure the battery is charged. If you left the doors open for a long time and "tested" your "sound system" then you may have drained the battery. Do you have any electrical power in the car at all?
If you can't even turn the engine over, then it's likely not a flooding problem.
As for the overheating and smoking, there can be several causes.
See this page for common cooling problems: http://www.aaroncake.net/rx-7/cooling.htm
What colour is the smoke?
Old Nov 21, 2007 | 09:34 AM
amarthfea's Avatar
there is also tons of good information archives pages, great thread if you really think its a flooding problem.
https://www.rx7club.com/2nd-gen-archive-72/how-bits-fc-wisdom-including-easier-unflooding-27438/ gives why the engine floods and one way you can fix it
Old Nov 21, 2007 | 09:41 AM
Force Fed's Avatar
Rotary Apprentice
You really need to do some thorough searching on here, if you still think RX-7's have head gaskets
Old Nov 21, 2007 | 11:58 AM
Juje's Avatar
Omg, I feel like an idiot... Some guy told me on a Different forum that I blew it. His name was Dodge Man ironically... I'm a n00b with Rotary engines! That's why I'm here...
The Color of the smoke is White.
Old Nov 21, 2007 | 12:12 PM
Fumi's Avatar
Addicted to the PNW
how fast are you blowing throught coolant?
as in does your coolant light/buzzer come on right after you start up the car?
do you have to refill your coolant everytime you drive it?
Old Nov 21, 2007 | 12:27 PM
Juje's Avatar
With in 5 minutes the buzzer goes on, yeah I have to refill it every time I try to drive it.
Old Nov 21, 2007 | 12:41 PM
black_88's Avatar
sounds like your coolent seals are toast.
Old Nov 21, 2007 | 12:50 PM
Juje's Avatar
What can I do to fix this?
Anyone? I need to fix this car already, it bugs me how it's just sitting there. In fact, yesterday a guy on my street has an M3, first time he saw the car, he slowed down, stopped, looked at the car for a minute, and parked in his drive way. Such a head turner.
Old Nov 21, 2007 | 01:40 PM
hhn2002's Avatar
get a new engine. haha well if its the coolant seals then rebuild or engine swap are the only options. coolant seals in a rotary are throughout the whole engine which would necessitate a complete teardown. might as well rebuild from there. anyways good luck. i had a problem once soon after i bought my 7 where the low coolant buzzer came on every 5 mins just like you. it was the coolant hose that was at the very back passenger side right under the intake mani that routed into the throttle body then through the BAC then back to the front. see if you can find any wet spots in the engine bay. you only want to rule out that it isnt coolant seals first.
Old Nov 21, 2007 | 01:49 PM
Juje's Avatar
Thing is I got the RX-7 for $600 , was working perfectly fine, my friend wanted to try and drive it, he doesn't know stick, kept stalling, when I got home, smoke coming out of the hood... Ah ****!
boog's Avatar
find a rotorhead local to you - but someone ligit - the kind of guy everyone goes to for answers - search for help in the west section of this forum - once you find reliable help with rx7's, you will be golden! forum help cannot really go that far at times - especially when 80 million people all have thier own answers
welcome to rotaries!
Old Nov 21, 2007 | 02:04 PM
hhn2002's Avatar
thats a freaking sweet deal. i'd suggest calling ur bro up if you havent already.
Old Nov 21, 2007 | 02:07 PM
Fumi's Avatar
Addicted to the PNW
yeah juje your going to need to get a differen't engine or rebuild yours because that engine is toast
oh and the white smoke most likely has a sweet smell to it, the cause of that is that the white cloud is all the coolant that was in your system
Old Nov 21, 2007 | 02:41 PM
Juje's Avatar
Just a question, how long will Rebuilding it my self take? or how much would it cost in general for a pro to do it?
Old Nov 21, 2007 | 02:57 PM
Aaron Cake's Avatar
Engine, Not Motor
White smoke, missing coolant, hard starting and overheating almost certainly points to a bad coolant o-ring.
The only way to fix this is to rebuild the engine.
Check the FAQ for links to some topics on how to rebuild an engine.
To have someone else do it will be $1000 at the minimum, and the price goes up from there depending on the quality of work and which parts will need to be replaced.
Old Nov 21, 2007 | 03:02 PM
Juje's Avatar
https://www.rx7club.com/1st-gen-archive-71/engine-o-ring-fix-269544/
Can that work?
Old Nov 21, 2007 | 03:09 PM
Aaron Cake's Avatar
Engine, Not Motor
No.
Old Nov 21, 2007 | 03:16 PM
Juje's Avatar
****, I'll call in some Local Rotary Specialist Shops. Thanks!
Old Nov 21, 2007 | 04:07 PM
Juje's Avatar
www.lucky7racing.net
Any Good?
I bought the FC from a Pro Drifter, he's sponsored from Dunlop. Justin Pawlak, I guess I can wait over time to fix my car.
alfred1976
RX-7 Audio/Visual Lounge
Dec 3, 2015 03:06 AM
Duc852
Sep 22, 2015 03:49 AM
