Block-Off Plate For Air Control Valve on SE
Old Nov 20, 2007 | 02:37 PM
rxforspeed's Avatar
CNC Mill/Lathe/EDM access
Question Block-Off Plate For Air Control Valve on SE
As the title states, where can I find a block-off plate for the ACV on the side of my lower intake manifold on an SE's 13b? Will the block-off plates from an S4 work (at least the ACV plate)? Thanks for all your help, guys...
-Adam Collins
Old Nov 20, 2007 | 03:06 PM
Latin270's Avatar
http://www.2751engineering.com/2751parts.html
Old Nov 20, 2007 | 03:35 PM
Midwest 7's's Avatar
sellout
just make one. use a gasket as a template.
Old Nov 20, 2007 | 03:36 PM
rxforspeed's Avatar
Thanks for the link Latin270, will the N/A S4/S5 ACV block-off plates work on my '84 SE 13b?
Old Nov 20, 2007 | 03:46 PM
rxforspeed's Avatar
I must have been searching in the wrong places, but I've finally found the answer on RB's website-'81-'92 N/A are all the same. I could make one from Diamond plate aluminum...Thanks for the help guys!
-Adam Collins
Old Nov 20, 2007 | 03:47 PM
Latin270's Avatar
Dunno brother, but the Mazdatrix website should give you more details.
Old Nov 20, 2007 | 05:09 PM
Atkins Dan's Avatar
Former Site Sponsor
All the galkest & block off plates are the same from 1981 to 1992 for the non turbo stuff...
Dan
Old Nov 20, 2007 | 08:20 PM
vipernicus42's Avatar
Rotoholic Moderookie
I don't think I'd use diamondplate... but I made mine out of sheet metal that's sold cheap for body repair work and cut it with a pair of tin-snips. Nice and easy. Nowhere near as thick as the RB one, but with 3 bolts and a good helping of high temp silicon it's no vacuum leak.
Jon
Th0m4s
Feb 26, 2019 02:04 AM
Snoopy FD
Dec 8, 2015 01:45 PM
