Fd fuel pump ina fc t2?
Old Nov 19, 2007 | 02:36 PM
re-rx7's Avatar
Vp in charge of Girls
How hard is it to put one of these in or is it a direct replacement?
Old Nov 19, 2007 | 03:38 PM
Craiger's Avatar
I believe it is a direct replacement, however you can probably get an aftermarket pump that is better for less money.
Old Nov 19, 2007 | 03:47 PM
djmtsu's Avatar
DGRRX
It takes 15 minutes. I am running an FD pump, $50 isn't too bad.
Old Nov 19, 2007 | 03:52 PM
re-rx7's Avatar
Yea my walbro just took a giant dump on me and i have one laying around. What is the flow rating vs stock fc t2 pump??
Old Nov 19, 2007 | 05:05 PM
introVert's Avatar
putting it down daily
*ears perking up*-
Just installed a tII pump in the s/c vert- not to hijack, but will this be enough to support 9psi of boost? If not, I may go FD...
Old Nov 19, 2007 | 05:11 PM
Jager's Avatar
Tear you apart
Food for thought for the OP. Give thanks to RETed.
http://www.fc3spro.com/TECH/MODS/FUEL/fpump.htm
But I do know alot of people use FD fuel pumps to support reasonable amounts of power.
Originally Posted by introVert
*ears perking up*-
With the Paxton unit I see alot of Walbros and FD pumps, but to tell you the truth I'm not 100% sure.
I beleive the most successful build that I know of (PianoProdigy's) ran a FD pump.
I hope that helps? If not, I'll just make this asian face.
Old Nov 19, 2007 | 05:52 PM
arghx's Avatar
rotorhead
The FD pump is really solid in terms of reliability. I have one in my old car which has at least 140k on it.
Old Nov 19, 2007 | 06:03 PM
sub9lulu's Avatar
just buy a supra pump and call it a day
toyota reliability + more flow / quieter than walbro ftw
Old Nov 19, 2007 | 06:56 PM
RETed's Avatar
It drops in directly for a Kouki FC.
For a Zenki FC, I think you need to lengthen the hose - very minor.
The FD fuel pump flows about 10% to 15% more than an FC turbo fuel pump.
-Ted
Old Nov 19, 2007 | 07:39 PM
introVert's Avatar
Note to self-
Get FD fuel pump + longer hose...
Thanks, guys
Old Nov 19, 2007 | 09:32 PM
re-rx7's Avatar
kouki would be a s5 correct
Old Nov 19, 2007 | 09:53 PM
RETed's Avatar
Yes.
-Ted
Old Nov 19, 2007 | 09:59 PM
AUGieDogie's Avatar
So what is the difference flow wise between FD and the Walbro?
Old Nov 19, 2007 | 10:13 PM
Sideways7's Avatar
Look halfway down the link posted above.....
Old Nov 20, 2007 | 02:10 PM
Chris Boots's Avatar
I blame the TPS
Direct bolt in. Works great in my TII
Old Nov 22, 2007 | 09:26 PM
NZConvertible's Avatar
I'm a boost creep...
You'd be lucky to get a better pump cheaper, as used FD pumps are dirt cheap. Plus if you install a "better" pump (assuming you mean a Walbro or similar) you'll need either an adjustable FPR or some sort of fuel control, because the base fuel pressure will be increased by a lot more.
Old Nov 23, 2007 | 01:12 AM
arghx's Avatar
rotorhead
Denso makes both the FD pump and the Supra pump, in addition to our stock fuel pumps. Denso pumps generally have a better reputation (and deservedly so) than Walbros.
In my own experience, the Walbro got the job done for my 250whp setup but the whining was irritating.
Old Nov 23, 2007 | 01:17 AM
CyborgRyu's Avatar
Drift FC
My FD pump got me up to 300rwhp. I'm running Walbro now; I kinda of like to hear the pump start because I know its working instead of hunting it down.
Old Nov 23, 2007 | 08:08 AM
BLK FC3S's Avatar
C088
+1
more flow than a walbro at 14 volts also.
Rotospectre
Mar 28, 2018 03:33 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
