Gauge cluster bulbs?
Old Nov 18, 2007 | 01:47 PM
RotaryMelon's Avatar
Has anyone changed the tired old bulbs in the first gen gauge clusters? specifically S2..
What type/size are they? or is it all just universal
Old Nov 18, 2007 | 02:24 PM
Jeff20B's Avatar
Lapping = Fapping
You have to take the cluster out. They are in little twist fittings. Not sure of the style but I have several bulbs.
Jeezus's Avatar
Stu-Tron Get Yo Groove On
LED's, anyone?
Old Nov 18, 2007 | 02:25 PM
Jeff20B's Avatar
Lapping = Fapping
Originally Posted by Jeezus
LED's, anyone?
Too much work and they're incompatible with the stock dimmer (I think).
Old Nov 18, 2007 | 02:31 PM
Jeezus's Avatar
I'll give it a shot sometime within the month. I got nothing to lose, I have no dimmer and I can't really tell the speedo after 80mph.
Old Nov 18, 2007 | 02:38 PM
Rx-7Doctor's Avatar
I believe the bulb number is 194 but you can use 168. If you are looking for brighter than have the parts guy check on the wattage difference between the two.
Old Nov 18, 2007 | 02:40 PM
Rx-7Doctor's Avatar
If you are going to take the cluster out then get a 83 unit. Then you will have the 130 MPH speedometer.
Old Nov 19, 2007 | 03:51 PM
wecycle's Avatar
Dash panel bulbs
When I replaced mine I used amber bulbs to get a more modern look and allow a bit more brightness. Biggest issue was finding a Phillips screwdriver with a long enough shaft to get to the screw in the bottom of the cluster.
Old Nov 19, 2007 | 03:57 PM
Jeezus's Avatar
I still got my spare 85mph here, I have a 140 or whatever in the car now. I will test it on the 85, and if it works, I will do it to the other one
Old Nov 19, 2007 | 04:32 PM
PercentSevenC's Avatar
I need a new user title
Yes, they are 194s.
Old Nov 19, 2007 | 04:59 PM
85 FB's Avatar
7-less
The higher the number, the higher the wattage. I know this because when I had to replace the cab lights on my '98 Kenworth, the bulbs weren't marked of which number. So, I had to match them up. Problem was that there were like 4 different numbers. I went with the higher number, a 922. Needless to say, that one bulb was bright as Hell compared to the other cab lights. So, I ended up having to replace the others with it. I like it, too. I love bright lights.
