in dash DVD won't play movies
Old Nov 18, 2007 | 09:54 AM
supraturbo1987's Avatar
Okay, i got a BOSS9900B in dash dvd for free from a buddy. I hooked it up to my daily driver. I put a movie and and I can hear the sound perfect, but there is a message on the screen that says, "video disabled while driving for safety purposes" Is there a way around this? I am not even driving, i was just sitting with the power ON
Trev
Old Nov 18, 2007 | 10:29 AM
PureDynamics's Avatar
Trev
All DVD units have a safety feature.. Check the wiring, there is a wire for the parking brake. They normally ground this wire and the screen will play video.
Old Nov 18, 2007 | 10:34 AM
really
Old Nov 18, 2007 | 10:36 AM
I didn't see anything for ebrake ground....
Old Nov 18, 2007 | 12:19 PM
1QWIK7's Avatar
White chicks > *
There is a wire from your unit that you have to splice into your e-brake.
This is to prevent you to NOT being able to watch movies while driving (hence the e-brake method).
E-brake up = you see video
E-brake down = no video
Ground that wire that is supposed to go to your e-brake and you will see video fulltime.
Trust me, i been through this before.
Old Nov 18, 2007 | 10:04 PM
turboIIrotary's Avatar
sometimes grounding does not work...i have a jenson in dash and i had to hack into the main menu to turn the safety off.
Old Nov 19, 2007 | 08:42 AM
John64's Avatar
What?
PAC makes units to bypass all of this. I had to get one for my Alpine unit.
Old Nov 19, 2007 | 05:31 PM
magus2222's Avatar
On the fasttrack!
or................like the pioneer headunits, it has a self grounding. no wires to hack into.
but, if it doesnt, then all you need to do is wire a switch inline with the deck, and voula, solved.
if it is like the pioneer n2 or n3, then you have to take it apart, find the ground solder and wire, cut a hole in the shell, then wire the switch.
peace
_Tones_
May 25, 2021 05:37 AM
Frox
Feb 27, 2016 11:11 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
