Question for tuners
Old Nov 8, 2007 | 12:50 AM
andre sinclair's Avatar
Question for tuners
I`m running a mircotech LT8s and I`m curious about my EGT`s under load.
Idle cold start AFR are 11.5-11.8 and my EGT`s between 600-800 degree Celsius
After engine warm AFR`s are 12.0 to 12.2 and EGT`s between 950-1100 degrees Celsius
While cruising at 3000 rpm / 10"hg my AFR`s 13.0 13.3 and EGT`s between 1300-1375 degree`s Celsius
Then when i punch it from cruise to high load 18 psi and run for a good strech my AFR`s is 11.2 but my EGT stays around 1300 degree. Is this NORMAL?
EGT sensor is located after the turbo in the down pipe.
Question is this safe... which do i trust the AFR or EGT?
Please advise!
Old Nov 8, 2007 | 02:10 AM
ZAN_TUNING's Avatar
Just turn up the boost!
you must mean fahrenheit, not celcius.. if so then that's about normal
Old Nov 8, 2007 | 08:35 AM
Yes, Fahrenheit my mistake.
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
Nosferatu
Sep 5, 2015 02:13 PM
