Coilovers
Old Nov 2, 2007 | 02:21 AM
viviorunitia88's Avatar
Boost like crazy
Coilovers
What are some of the "best" coilovers out for the fds either track or street dont matter also price not an option
Old Nov 2, 2007 | 09:28 AM
ikpfal's Avatar
You need to be more specific on what type of driving you are going to be doing when selecting a set of coilovers, or any type of suspension modifications. There are a lot of equations that need to be worked out from how you drive to wheel and tire selection. This subject has been cover alot and you can find lots of reviews on different brands out there.
Old Nov 2, 2007 | 09:58 AM
gracer7-rx7's Avatar
needs more track time
might want to search this section for that information. that topic has been beaten to death over the last 4 years.
Old Nov 2, 2007 | 11:32 AM
Mahjik's Avatar
Mr. Links
You can buy Koni shocks and then have them changed over for double adjustments for about $300-400 per shock. So, about $600 for all 4 shocks and then another $1600 to have them changed over for double adjustment. Add the Ground Control coilovers sleeves with custom spring rates from Eibach (about $600). Be sure to pick the spring rates first so when the shocks are rebuilt, they are matched for your spring rates.
That will give you about the best bang for the buck (about $2800 for the setup).
Old Nov 2, 2007 | 12:21 PM
Roen's Avatar
The Silent but Deadly Mod
Penske quadruple adjustable coilovers. $12,000.
He did say price isn't an option, right?
Old Nov 2, 2007 | 12:24 PM
Boost like crazy
a
ok mostly for street as well as roadrace and drift thats what the coilovers are going to be used for
Old Nov 2, 2007 | 12:43 PM
Roen's Avatar
tein drift is common.
Personally, I'm not a big fan of the suspension aftermarket.
Old Nov 2, 2007 | 12:49 PM
Boost like crazy
a
i was looking at the stances, cusco zero 2s, and the zeal function d
Old Nov 2, 2007 | 12:52 PM
2MCHPWR's Avatar
FD / LSX
JRZ makes a set for the FD:
http://www.jrzusa.net/
but they don't come with springs.
Old Nov 2, 2007 | 01:16 PM
Mahjik's Avatar
Mr. Links
IMO, find the spring rates that you want to use and build the custom setup I mentioned above.
Old Nov 2, 2007 | 01:40 PM
Enthu's Avatar
Still has an RX7.
^I agree. From what I've read, the custom Konis are the best way to go. I've got Koni yellows. I bought them so I can upgrade them later if I start doing alot of tracking.
Just with the rebound damping, they are great dampers so far and I'm happy I chose them.
Old Nov 2, 2007 | 01:50 PM
Roen's Avatar
mmm, $4k for JRZ......
I'd say the Custom Koni/GC is like the JRZ RS
you could also make a Custom Bilstein/GC that's like the JRZ RS Pro. Just need to find you some Penske/Ohlins remote reservoirs.
Old Nov 5, 2007 | 10:13 AM
GARRETT@TRIPOINT's Avatar
Penske shocks with Eye to Eye top mounts for bearings on both sides that we make.....PM me for pic of the top hats and the shocks and pricing!!!!
Old Nov 5, 2007 | 09:00 PM
Bunchies's Avatar
Ohlins
Old Nov 5, 2007 | 09:29 PM
drftwerks's Avatar
aragost are probably a good coilover for you, better than most, and not as expensive as what was listed above
Old Nov 6, 2007 | 08:28 AM
Roen's Avatar
I like the fact that Koni has independent rebound and compression (if you want to pay more for it) adjust.......you just can't fine-tune a suspension in lockstep like 99% of the dampers out there.
Old Nov 6, 2007 | 07:06 PM
WorkS2R's Avatar
money no option - definately ohlins or penskes t/a or q/a ..
but realistically, if you are going to street your car, the farthest i'd go is T/A...
Old Nov 6, 2007 | 09:06 PM
Roen's Avatar
Street car? Farthest i'd go is d/a......$ to benefit ratio skyrockets after d/a.
Old Nov 6, 2007 | 10:00 PM
WorkS2R's Avatar
when i say .. "you are going to street your car"
it means, you mainly have it on the track, but may want to drive it on the street every-so-often
I think T/A is such a big difference on track vs D/A - but still not rediculous where you need to reset every time you get off the track
