Wheel size question
Old Nov 1, 2007 | 03:33 PM
Robíño's Avatar
Wheel size question
I am about to buy a set of rims for my FD, rear ones are 18x11.5 -9 and front ones 18x10.5 +3
How do this rims fit on the FD? Will they be able to mount?
I will go widebody but how much more then original rims will they stick out? I meenm, how many mm longer out will the rims edge be then the original ones?
Thanks!
Old Nov 1, 2007 | 03:46 PM
phillip.ma's Avatar
unless you have a widebody kit on the car its really not worth it... the tire hitting against the wind when your driving is going to be insane... i mean, im not an expert on the matter but its going to be a safety issue as well as a cosmetic one.
to get your wheel size and your offsets and to see if they fit you need to check the tire your buying and if it would fit your wheelwell... i dont quite remember the 7's cause its been a while.
go to tirerack.com and it'll show you what actually fits on your car.
Old Nov 1, 2007 | 03:48 PM
Robíño's Avatar
thanks for the tip..will check right away.
but I'm going to go widebody so thats aint the matter I just weant to know if they fit on the inside of the rim and how far out they will stick if you compare to a original rim.
Old Nov 1, 2007 | 09:42 PM
owen is fat's Avatar
they will be outside about 2 inches in the rear from the stock fender lip, thats a lot.. 50mm, wow.
almost the same in front.
good luck.
Old Nov 1, 2007 | 09:55 PM
gio64's Avatar
Not sure about tirerack...
I don't know if you can actually trust the list of wheels that are deemed to fit at tirerack.com. I was looking at Motegi traklite and they don't show as available under the FD, however, their fitment in 17" is as close to stock as you could possibly get... There are other wheels there that have more "fitment issues" if I can call them such, that instead are listed under the FD....
Up to you.
Old Nov 2, 2007 | 03:40 AM
Robíño's Avatar
good luck.
But how will it be on the inside of the wheel? Will it fit there?
From where the wheel is mounted how far in will it go? As original, will it be to deep so it wont be able to mount it?
Old Nov 2, 2007 | 07:14 AM
you will have more than an inch of wasted space (clearance) inside between the wheel and the suspension.
if an 18x10 +50 just clears the suspension.
then an 18x11 +38 just clears the suspension.
and an 18x12 +25 just clears the suspension.
roughly... specific wheels may differ because of wheel construction and variation between manufacturers... but you get the idea.
the wheels you are looking at are what would fit a widebody FC pretty well
Old Nov 2, 2007 | 07:32 AM
Robíño's Avatar
yeah i know...they come from a widebody FC, but I want them on my widebody FD
You think its a bad thing to do to put those wheels on my FD?
how much wider then original rims are those?
Old Nov 2, 2007 | 08:46 AM
Mahjik's Avatar
Mr. Links
Stock rims are 16x8 +50.
Old Nov 2, 2007 | 10:39 AM
RETed's Avatar
Actually, they are not that great a fitment for an FC either... :P
10.5", +3 will tend to hit the front suspension unless we're talking coilovers that give you addional clearance or stretched tires.
11.5", -9 sticks out 1/2" farther out - more waste space on the inside.
Sorry for the tangent...
-Ted
Old Nov 2, 2007 | 11:13 AM
they are a bad fitment for FDs in my opinion, because the FD can fit so much tire under a stock fender, once you go widebody you can fit HUGE wide meats in there, might as well go for it with 11's /295s up front and 13's /335s out back
those wheels will clear the inside so you can use them.
in fact those might just barely fit a burnout kit'd FD with 255 fronts and 285 rears if you like that sort of tire-to-wheel sizing.
Old Nov 2, 2007 | 08:11 PM
Robíño's Avatar
I'm not going to use a widebody kit...averything is going to be handmade.
the thing is that i dont want wider tire than 305 but I also want the distance between the wheels to be big so this kind of setup would be nice and I dont need spacers
roms of this size what is heavy and what is light...the rims I am looking at weight 9.5 kilograms, is that heavy or light?
Old Nov 11, 2007 | 11:00 AM
Robíño's Avatar
anyone?
Old Nov 11, 2007 | 11:26 AM
Mahjik's Avatar
Mr. Links
9.5kgs is around 20lbs. The stock 16x8 rims are about 16lbs (for the heavier iteration) which is around 7.2 kgs. 20lbs for a 10"+ wide rim is pretty good.
ChrisRX8PR
Aug 21, 2015 01:56 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
