AFRs at idle
I can can get as lean as 13.5 afr or just to about where lean misfire would occur with 1600cc injectors. Idle is perfect around 13.0 afr.
Trending Topics
AFR of 12.5 is not to bad for that ecu injection mode/setup etc. but it also depends on the rest of the setup like fuel pressure and ignition timing at idle.
the leanest i can get with still a smooth idle is about 12.5.. with 750cc primaries, rtek 2.0, stock timing, stock ports.
crispeed, what timing are you running at idle?
is there any connection between requiring a rich idle and low (er lower but still serviceable) compression due to general wear
I can't get mine to idle happy any leaner than 12.5 at idle with an E8
mine runs smooth at .92 lambda and its a bridgeport..
jantore, I was under the impression that the autronic ecu's had some pretty badass injector control and could accurately fuel at quite low pulse-widths..
how streetable is a car with 1600 or 1680 CC primary injectors?
What is the base fuel pressure set at, and how much effect does this have on the setup
What does the rest of the fuel system look like?
for my own purposes 2x1680 CC injectors would supply all of the fuel I could need. It would be cool as **** to simplify the system and just have one set of injectors.
