V-band clamp question
Old Oct 29, 2007 | 03:19 PM
palsor1's Avatar
Hey guys,
I've got an A-spec kit, and the turbine to downpipe connection, the manifold to wastegate connection, and the wastegate to downpipe connection are all V-banded. I'm new to V-bands, so my question is how tight should I tighten them down?
1. Should I just tighten them until the nut feels good and tight?
2. Should I keep tightening until the V-band is completely closed?
3. Should the V-band close all the way pretty easily? Mine aren't.
Thanks!
- Andy
Old Oct 29, 2007 | 03:26 PM
Viking War Hammer's Avatar
*** Bless The USA
Tighten it until you hear knuckles start cracking, then back off 3.5 turns.
Old Oct 29, 2007 | 05:02 PM
wackaloo13's Avatar
did a bit of poking around and seems like 110-130inlbs is standard for vband clamps, atleast for the turbo to dp one
Old Oct 29, 2007 | 05:24 PM
PandazRx-7's Avatar
Fast + Reliable = $$$$$
I just installed and tightened these on an A-spec 500r kit... the only one I recall that tightened up ALL the way was the wastegate to downpipe connection (the smallest one I believe). The rest weren't all the way, but just get them pretty darn tight withought breaking any bolts.
Old Oct 30, 2007 | 12:03 AM
wackaloo13's Avatar
make sure to go through and retighten the clamps after you drive it for a bit, they seem to seat themselves a bit and need to be cranked down again after a while
Old Oct 30, 2007 | 12:14 AM
palsor1's Avatar
Ok thanks guys. Since I can't get the vbands to close all the way I was concerned something was wrong, but it sounds like that's pretty normal. I'm hoping to get the car started over Thanksgiving, so we'll see if I've got any leaks then I suppose .
- Andy
_Tones_
May 25, 2021 05:37 AM
