T3/T4 too small?
Old Oct 26, 2007 | 10:13 AM
rotaryboy23's Avatar
T3/T4 too small?
Looking at a turbo available in my area...
"It has a ported and polished inlet bell, polished intake housing, and comes with an adjustable wastegate.
A/R is .60/.63 Hot/Cold. "
He wants $350 neg.
At what kind of (ballpark) numbers would this become too small for a 87 6-port NA thats going to be rebuilt, maybe minor porting? Car needs to stay streetable, so I figured this may be a decent option... I know I'm leaving a lot of variables, but I've barely started in on the motor, so I haven't decided on aiming for anything! Open to suggestions, and lotsa info! thanks!
Old Oct 26, 2007 | 10:39 AM
RacerXtreme7's Avatar
NASA geek
Too small, you'd be better off with a TII stocker.
~Mike................
Old Oct 26, 2007 | 02:02 PM
I thought the stocker was around a T3 size? Must be my mistake. thanks!
Old Oct 26, 2007 | 02:19 PM
diabolical1's Avatar
a turbine that size would worry me on a rotary. my opinion: you'd be asking for trouble. stock turbo or maybe something like a 60-1.
Old Oct 26, 2007 | 02:22 PM
NASA geek
Your tittle says t3/t4 which is a hybrid, t3 turbine and t4 compressor. The stocker's turbine is equivelant in size to a t3 and its compressor is yes close to a t4. The turbo you described even though you listed no trim levels I know already is too small due to the A/R values you listed (way too small turbine A/R regaurdless of the trim, and the compressor A/R although not as critical I know that only small trim compressors come with such a lame A/R, so its a small trim compressor). The answer is NO, its too small, let some Honda guy buy it.
~Mike............
Old Oct 26, 2007 | 04:16 PM
arghx's Avatar
rotorhead
yeah that thing would be better on a single cam civic or something
Old Oct 26, 2007 | 04:29 PM
BoostedFd3s's Avatar
ninja
way too small.
Andrew7dg
Aug 6, 2017 01:41 PM
Jetlag
Sep 29, 2015 06:52 AM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
jarjarbinks
Sep 25, 2015 11:03 PM
