a/f ratio guage
Old Apr 10, 2002 | 10:34 PM
presetlimits's Avatar
a/f ratio guage
when running the signal wire and connecting it to the wire under the hood, do you connect it on the sensor side of the connector or the side running back to the harness?
Old Apr 10, 2002 | 11:10 PM
NZConvertible's Avatar
I'm a boost creep...
Neither, you should really connect it at the ECU end so you don't disturb the shielded wire in the engine bay. You can easily get power and earth there also.
Old Apr 10, 2002 | 11:14 PM
is there a good writeup and/or pictures for this?
Old Apr 10, 2002 | 11:16 PM
dra_gon_lee's Avatar
yes i need to know also, where do i connect the sensor wire on the ecu...
thanks
rocky
Old Apr 11, 2002 | 01:17 AM
rx7_turbo2's Avatar
Professor D.P
Download the factory service manual, there is a section that tells you what every wire going to the ECU does.
Old Apr 11, 2002 | 01:26 AM
White94RX's Avatar
BMW Tech
Where can I download the service manual?
Old Apr 11, 2002 | 01:54 AM
Scott 89t2's Avatar
SOLD THE RX-7!
both the 86-88 and 89-91 ones are at www.fc3s.org
Old Apr 11, 2002 | 06:47 AM
what would it be under on the manual?
Old Apr 11, 2002 | 07:16 AM
bob13bt's Avatar
Fixed the wheelhop
I believe its under the Fuel & Emissions chapter....
Old Apr 11, 2002 | 10:36 PM
is there a way to get this guage backlit anyhow besides just the leds that flash?
WyomingTII
Sep 28, 2015 10:32 AM
