Will resurfacing my flywheel w/o putting on a new clutch hurt?
Old Apr 10, 2002 | 08:45 PM
Turblown's Avatar
Turn up the boost
Question Will resurfacing my flywheel w/o putting on a new clutch hurt?
so will it? I just replaced the oil seal behind the flywheel and i didn't want to take any shortcuts, but i just replaced my clutch like 6 months ago, and so will having it resurfaced do any damage with my old clutch disc? just want to be sure...
Rotary Performance Parts
Old Apr 10, 2002 | 09:06 PM
Ranzo's Avatar
If you have it done professionally NO. Is your Flywheel bowled, meaning the center of the area where the clutch touches deeper than the outside, or is it messed up in anyway? If you are running a stock clutch I doubt that you would need to have it resurfaced.
I can't remember is the stock flywheel is a 2stage flywheel or not, ( haven't had one in years) but if it is then you will have to mill both areas in exact increments or damage will most likely occur to your clutch.
When looking at your flywheel and you only see some dark blue hot spots or some residual clutch there you can just use some sand paper and clean those areas up, I always sanpaper the pressure plate and flywheel anyway before assembling.
Randy....
cristoDathird
28
May 30, 2019 08:47 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Captain_Panic
Alternative Fuels
Sep 16, 2015 02:06 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
