Does ANYONE make a nice e-brake handle.....
Old Oct 23, 2007 | 11:25 PM
frankadelic's Avatar
Frankie V
Good god this wouldn't seem like a hard thing to find but I cannot find any after market e-brake handles along with a nicely finished release button...I had to take my OEM one off and as you probably know it's glued on and has to basically be cut off (destroyed) to get it off...anyway anyone out know where to look?....Something nice befitting an FD..
cheers
Old Oct 24, 2007 | 07:10 AM
darksideperformance's Avatar
+1
Old Oct 24, 2007 | 12:31 PM
Oun's Avatar
Oun
I can confirm.
+2
Old Oct 24, 2007 | 01:00 PM
PowerStripe's Avatar
Dreams come true
+3
Old Oct 24, 2007 | 01:47 PM
Haha, might need to do a little modeling in solid works I think. Any body in the market for matching polished or coated aluminum shift **** & brake handle? Most likely won't be real cheap (short production run), but can be done.
Old Oct 24, 2007 | 03:34 PM
asiansuperstar's Avatar
Try the mazdaspeed website. They make a really nice e brake handle that goes for the Miata but looks like it'll fit for the fc/fd
Old Oct 24, 2007 | 04:57 PM
Wompa164's Avatar
I've got the MazdaSpeed titanium shift **** + ebrake handle and I think it's awesome
Old Oct 24, 2007 | 11:02 PM
mikewoodkozar's Avatar
Brap, Brap, Ole!
^ Pics?
Old Oct 25, 2007 | 12:43 AM
turbodrx7's Avatar
PURIST
I bought a voodoo e-brake handle a while back and have been very happy with it. I wanted something simple and it fit very well.
-Austin
Attached Thumbnails Does ANYONE make a nice e-brake handle.....-dsc02080.jpg
Old Oct 25, 2007 | 01:44 PM
turbodrx7's Avatar
PURIST
Here is a working pic. I went with the brushed aluminum look with mine.
-Austin
Old Nov 4, 2007 | 05:40 PM
saeedm's Avatar
I like the original much better. The only e-brake that might look better/more fitting would be the Japanese version w/ red stitches to match my black/red interior
Old Nov 8, 2007 | 02:46 AM
eli809's Avatar
looks better then the fc one!
Old Nov 8, 2007 | 11:02 AM
introVert's Avatar
putting it down daily
^^true. I want one!
Old Nov 8, 2007 | 04:35 PM
Mybaby's Avatar
Mazdaspeed CF Ebrake
Picked this ebrake handle up from japanparts.com.
Attached Thumbnails Does ANYONE make a nice e-brake handle.....-cfhandle.jpg
Old Nov 11, 2007 | 07:48 AM
introVert's Avatar
Carbon junkie- mmmmmm
Old Nov 11, 2007 | 02:19 PM
B_Hydra's Avatar
Objection!
Awesome! Thanks for the picture -- I know exactly what my replacement will be, now...
Old Nov 11, 2007 | 11:43 PM
Mybaby's Avatar
Talking
thanks
Old Nov 16, 2007 | 01:08 AM
Vagrant02_DRFT's Avatar
Touge Friend
Old Nov 16, 2007 | 03:50 AM
BigWillieStyles's Avatar
That gauge pod, where can i get it? Looks the goods.
Old Nov 16, 2007 | 10:48 AM
Smitter's Avatar
94 Single Turbo FD
heres mine. its a momo steel if i remember correctly. i think they also have cf, aluminum and titanium finishes aswell.
Attached Thumbnails Does ANYONE make a nice e-brake handle.....-c091707_0112_01.jpg   Does ANYONE make a nice e-brake handle.....-phone-pics-011.jpg
Old Nov 17, 2007 | 04:41 PM
Mybaby's Avatar
The gauge pod is from RX7.com.
Old Nov 17, 2007 | 11:40 PM
B_Hydra's Avatar
Objection!
Do you know if your Mazdaspeed carbon fiber ebrake handle is the same one as is listed for use on the Miata (on Japanparts.com) or did you find it listed as an RX-7 part? (Part #183-005-004)
Old Nov 19, 2007 | 11:15 AM
Mybaby's Avatar
I got the ebrake handle about 1 1/2 yrs. ago. Back then for for the FD/RX-7 in the section labeled interior under the Mazdaspeed parts was the CF shifter and ebrake. I am not seeing either now. They must be discontinued. Looks like they still offer the titanium stuff.
I wouldn't go with anything for a miata unless you know specifically that it will fit properly.
Remeber with most aftermarket handle your going to have to rip off the OEM handle. So be prepared to sacrifice your OEM look.
Good luck finding it.
Dave
Old Nov 19, 2007 | 12:37 PM
Smitter's Avatar
94 Single Turbo FD
use a heat gun when u remove the factory handle and u can slide it off. takes a little elbow grease but it will come. keep heatin it. then u can reuse it down the road if u choose
Old Nov 19, 2007 | 01:22 PM
B_Hydra's Avatar
Objection!
@Mybaby
I'm okay with losing the OEM look if the pieces are nice -- my OEM parts are a bit worn.
@smitter113fd
I'll keep that in mind when I find a nice e-brake replacement...
