Help I need info on what my oil pressure guage should read at idle
Old Apr 10, 2002 | 08:21 PM
coolrotaries's Avatar
I need to know if my autometer guge is reading correctly at idle. At 940-1000 rpm it reads 10psi. Is this ok??? If I lower the RPM to 880 it reads about 5psi-opsi.
I need to know if I'm damaging the engine.
Also what should it be reading on acceleration and on boost??
Any help would be greatly appriciated. Thanks Diego
Old Apr 10, 2002 | 09:23 PM
10sec rx7's Avatar
10psi is a fraction low, my engine reads about 30psi at idle, up in the rev range it reads up to around 80psi,
my old motor had the same problem a o ring was going in the oil pump and leaking out pressure.
Dale
Old Apr 10, 2002 | 09:31 PM
is that reading on a 6 series?
andyvideopro
Aug 20, 2015 10:55 AM
20B Forum
Aug 18, 2015 02:46 PM
